Old 09-02-2014, 07:47 PM   #1
davepl
davepl's Avatar
A different loose mirror problem
Someone was asking about the roof mount joint, but my LMC repro mirror has a different problem: the ball and socket part is loose.
Is there any kind of adjustment, or what else can I try? I was born in Canada so my natural instinct is to put some maple syrup on it so it gets sticky and doesn't flop around, but there's probably a better way.
Ideas? I still have my original, so if I could transfer the mirror to my original (where the mirror is damaged) so long as I can polish out the stainless well enough.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-02-2014, 07:54 PM   #2
tcrist
Re: A different loose mirror problem
I would think that there should be a screw somewhere to set the pressure. If not???
Maybe someone else that has one from LMC will chime in.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 09-03-2014, 12:18 AM   #3
FirstOwner69
FirstOwner69's Avatar
Is the repro mounting bracket different from the original style in the picture below? The originals allow you to tightened the arm in the socket by turning the screw. If not, will the repro mirror fit in the factory arm?
FirstOwner69 is offline   Reply With Quote
Old 09-03-2014, 10:08 AM   #4
Fitz
LMC = Lots More Chinese crap.
Fitz is offline   Reply With Quote
Old 09-03-2014, 11:08 AM   #5
briscuba
briscuba's Avatar
I was the one that posted the "other" loose mirror post. I have the same mount as the pic above and can definitely tighten the bolt down tight around the ball... I am wondering if some of the after market parts are just off enough that they are presenting adjustment issues...?
I am going to the parts bin for shimming possibilities, just a thought.
Brian
1970 SWB CST 400, 402/400TH, AC, PB, PS
briscuba is offline   Reply With Quote
Old 09-03-2014, 11:15 AM   #6
leftybass209
leftybass209's Avatar
The solution I had originally gave to briscuba was to replace that aftermarket black bracket with an original if you still had it. Chances are the stamping, gauge thickness, and better quality of the original will allow you to tighten that up. I utilized parts from an aftermarket and an original to create mine as I had both on hand already.
leftybass209 is offline   Reply With Quote
