Old 09-03-2014, 12:44 PM   #1
jaime.gtz78
Quick offset question on some wheels
I won some amazon credit from work and wanted to use it to purchase some wheels for my 68 c10 2wd and only wheels i found on there that i like are the Torq Thrust IIs. Only size available in 20 inch wheels are 20x8 5x127 0mm for the front and 20x10 6mm for the rear. Will these tuck if i decided to bag my truck later?
jaime.gtz78 is offline   Reply With Quote
Old 09-03-2014, 01:38 PM   #2
jaime.gtz78
Re: Quick offset question on some wheels
Sorry I know the front will tuck I meant the rear wheels
Old 09-03-2014, 01:40 PM   #3
texasld
texasld's Avatar
I would like to know too!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 09-03-2014, 07:28 PM   #4
Fitz
Stepside or fleetside? What section width tire will you use? Disc brakes or drum?
You can make literally anything tuck but to do it you need to know the dimension from the inner edge of the wheelhouse to the mating surface of the wheel, the distance from the mating surface of the wheel to the inner edge of the outer wheelhouse and the distance from the frame to the inner edge of the outer wheelhouse. Pics are 14 inch wide rims with 17 inch section with tires on a 67 stepside. They have 1.5 inches clearance on each side.
Fitz is offline   Reply With Quote
Old 09-03-2014, 07:40 PM   #5
jaime.gtz78
Sorry fleetside bed and have drums now but I'm converting to disc brakes all the way around or may decide to just do disc brakes in the front and keep the drums in the rear.
