Old 09-02-2014, 09:13 PM   #1
laid67c10
laid67c10's Avatar
2002 z06 vette motor good deal?
Found a complete z06 motor with ecu and harness, only has 35k mikes on it. For $2000, was gonna put a 5.3 in my truck but this is only $2000 so I figured I'd buy it instead! What tranny do y'all recomend I put behind it? Gonna leave it mainly stock except probably just cam it.
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 09-02-2014, 09:20 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 2002 z06 vette motor good deal?
That would be an LS6, so if you can verify the miles, id say its a great deal!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-03-2014, 01:57 AM   #3
solidaxel
solidaxel's Avatar
Your perference !
Auto or standard
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-03-2014, 10:30 AM   #4
laid67c10
laid67c10's Avatar
Originally Posted by solidaxel View Post
Your perference !
Auto or standard
I'm thinking a good 4l60e should be sufficient enough, I'm not trying to build a race truck, just a good reliable driver with a lil power.
Old 09-03-2014, 10:34 AM   #5
solidaxel
solidaxel's Avatar
4L60E is GREAT, I have three of them and they are "Wonderful", GOOD Choice!
LS 3 4L70E
Old 09-03-2014, 12:23 PM   #6
Xeen
Xeen's Avatar
The 2002 Z06 was underated by 20HP which means it has 425HP from the factory and there is no way a stock 4L60E can handle that kind of power for an extended amount of time in a truck because of the weight and the amount of money it would cost to upgrade it to where it would even hold up for a while before it failed isn't worth it and don't be lured by the pipe dream of a 4L70E either because they have a super high failure rate in the TBSS because of the weight of the SUV.
I would put a 4L80E in it instead, it costs a little bit more but it can handle anything you throw at it.
You will have to buy a TCU no matter which electronic auto transmission you go with because that ECU exclusively controls the engine since the Z06 only came with a manual transmission.
IMO if you want a auto transmission the 4L80E is the only way to go for a high horsepower engine in a heavy truck.
With the super low price you are getting the motor for you can afford the 4L80E and the TCU.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-03-2014, 12:43 PM   #7
laid67c10
laid67c10's Avatar
That is what I will look for then! Thanks for the info! If everything works out I'll be picking the motor up Sunday!
Old 09-03-2014, 01:09 PM   #8
solidaxel
solidaxel's Avatar
Thanks for the updates on power, I will remember that in the future
LS 3 4L70E
Old 09-03-2014, 11:23 PM   #9
ls1nova71
ls1nova71's Avatar
The PCM from the Z06 will work with an automatic transmission, you will just have to have it tuned for what ever trans you decide to put behind it. Keep in mind that adding a 4l80e to it will require some good tuning software since they are different than a 4l60e in terms of the tune, but any good tuner can handle this for you. You will have to modify the harness, and will have to add the automatic trans wiring to it, but that isn't hard to do, and you will most likely want to reroute some of the harness anyway to fit your application anyway.
Old 09-04-2014, 12:21 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have 3 as well, and I don't think a single one isn't at least a little broken
GM shouldn't make a trans without letting me break test it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-04-2014, 01:23 AM   #11
Xeen
Xeen's Avatar
LS1Nova71 knows way more about the PCM and wiring than I do, I would take his word for it if I were you.
I made an assumption that GM wouldn't add code for transmissions they knew they would never use in the car, but apparently I was wrong.
The good news is you won't have to buy a TCU because they are expensive.
Now you can focus on finding a low mileage 4L80E, Get R Dun!
Old 09-04-2014, 01:42 AM   #12
Xeen
Xeen's Avatar
yikes what are you doing to those poor 4L60E's?
For the love of Chevy get a 4L80E!
Old 09-04-2014, 10:13 AM   #13
Wasted Income
Boosted Member
Wasted Income's Avatar
Agree 1000%
Absolutely correct. All it takes is a transmission segment swap. Ridiculously easy to do with EFI Live or HPT.
You too? lol. I've killed and helped kill more 4L60Es than I care to remember.
Yup. It really is as simple as flashing a 4L60E transmission segment into the LS6 PCM. I've also put together other LS combos that "never existed" and flashed them....5.3 with a manual....5.3 with a 4L80E, LS6 with a 4L80E
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 09-04-2014, 12:29 PM   #14
aggie91
I'm just glad to be here!
aggie91's Avatar
If you need a trans, I have a 4l60e that is a good core. I know the 3-4 clutches are burnt but can be rebuilt. I could make you a deal on it...
The harness mods are easy and I did my son's truck myself. I sent my PCM off for tuning and it fired up the first try. If you need help on the harness, give me a shout, we could work something out and I am local to you, real close since you are living in my old house...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-04-2014, 01:54 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've got an 80e in the '66, and we haven't blown up the T56 in the fbody yet.
With the weight, power, and size/weight of tires I've got on here, its not hard to burn out a 60e. I've also burned one out in a Bravada while towing, and blew up my old 700r4 by wanting to actually drive it....
Old 09-04-2014, 01:59 PM   #16
Wasted Income
Boosted Member
I looked at one sideways once and broke a forward sprag.
I farted while leaving a stop light and broke a sun shell.
Turbo diesel
Old 09-04-2014, 02:25 PM   #17
boostedc10
boostedc10's Avatar
At least you got the fart out, I thought about a fart and broke the sun shell.
For sure with the weight of the truck and to not have to worry about it when you decide to add a little more power (which we all do) the 4l80e is the way to go.
The segment swap with HP Tuners is as simple as download your file, send it to them, they swap the data in the transmission segment and send it back to you.
The wiring is very simple and you can use the terminals you pull from the round plug to wire up the ISS and not have to add any additional wire.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-04-2014, 04:01 PM   #18
laid67c10
laid67c10's Avatar
Small world! Lol I'm not sure what I'm gonna do, the guy I was gonna buy the motor from seems shady so I'm gonna go with my gut and pass on the motor for now, I'm gonna yank the small block 400 out and focus on getting the frame where I want it, all porterbuilt components for the front, and the rear I'm up in the air, I don't know if I wanna build a custom back half or go with porterbuilt, it's gonna get 24x15's, after that, then decide on what ls motor I'm gonna do!
Old 09-04-2014, 04:14 PM   #19
Xeen
Xeen's Avatar
You can do whatever you want to but it's a pain to put anything larger than a 20x8 wheel on the front of a c10, a 22x8 can be done with slosh tubz, but I have never seen anyone do a 24" I think that may be too much.
Old 09-04-2014, 04:37 PM   #20
laid67c10
laid67c10's Avatar
My buddy has 24's on the front of his 69 burb, running all porterbuilt extreme dropmember and components! But I'm leaning towards 22's for the front anyways! 24x15's out back for sure though!
Old 09-04-2014, 04:45 PM   #21
laid67c10
laid67c10's Avatar
My buddies burb! 24's all around with 24x15's out back and a 6.0 LS conversion!
Old 09-04-2014, 06:50 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
damn thats clean.
ONLY downside is that you have to basically narrow the front or run an offset that puts the wheel inward if you want to not have hella-camber when dropped out.
Old 09-04-2014, 06:59 PM   #23
boostedc10
boostedc10's Avatar
That burb is gorgeous
Brandon
Instagram: DRVFSTR
Old 09-04-2014, 07:06 PM   #24
clinebarger
Another 4L60E Hate Thread
clinebarger is offline   Reply With Quote
Old 09-04-2014, 10:14 PM   #25
Xeen
Xeen's Avatar
I saw a guy do 24's on the back of his truck and they are so tall he had to use the 67/68 narrow rear axle with a 5 lug conversion and cut the top rail of his bed to get it to lay down, I was like umm...that's just not worth the expense and the bed mutilation, seriously it would be much, much simpler and a lot cheaper if you went with 20" front and rear, unless you just like pain and spending money.
