Hydramatic tranny question.
Can anyone confirm this? I've been under the impression that hydramatic tranny's didn't have any "park" built into them. I take a magazine called "Hemmings Collector Car" and the subject came up recently and it was mentioned that they had no park. Someone wrote in and said that they did have park. According to them, you switched off the engine and then moved the shifter to the "reverse" position and this put it in park.
Anyone here ever heard this, or have a hydramatic that can try it? |
#2 | |
Re: Hydramatic tranny question.
http://en.wikipedia.org/wiki/Hydramatic I got this info by Googling "hydramatic park".
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
Thank you. I should always google something before I ask, LOL.
The magazine article I mentioned above was about a 54 GMC truck with factory Hydramatic and it was mentioned in the article that there was no park. I wonder if the owner even knows he does have a park. |
#4 | |
When I bought my '54, it had a '49 Cadillac engine and transmission (4 speed). With engine running, shift lever all the way down was reverse. Turn engine off and all the way down was park. How this works in the guts of the transmission I don't have a clue.
I never trusted using the park and always turned my front wheels to the curb where possible. Never had a problem. Clay |
#6 | |
From the manual: "When the engine is not running, reverse can be used as a parking brake by means of a parking pawl which holds the reverse internal gear. When the engine is running main line oil pressure behind the parking blocker piston will hold the parking pawl clear of the reverse internal gear for normal operation of reverse." These guys just thought of everything. Last edited by 1project2many; 05-13-2014 at 07:12 PM. |
does anyone still make the small plastic/glass lens/bezel my dad and I have restored an old 1957 chevy step side truck he got when he was 16 but in the process we acedently broke the glass piece
Go to your local hardware store get the right thickness of plexiglas. Sand and shape to match the original. Finally make a GOOD TFF picture file of the Shift Pattern and take it to a local trophy Shop That uses a LASER engraver, they can cut the letters, Polish the surface apply white paint into the letters then wipe off (DONE)
Wrong year , but here is what they looked like after
