Old 09-06-2014, 01:10 AM   #2001
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by swamp rat View Post
Looking good!
thanks, I did not get the tank in the truck this week. raining
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 09-06-2014, 01:20 AM   #2002
gdavis
gdavis's Avatar
Re: 1968
Today, I made a 4 x 4 hole in the backing bracket for the flip down tag holder. I really like the flip down tag holder, it stays open when I am putting gas in the tank. This way I don't have to fight with the tag. The hole is for the gas inlet to go through. I also painted the backing bracket and the flip down tag holder black. I made the holes in the tag light square. This way I can use 1/4" stainless square holed bolts. I call them stove bolts, but I can't remember what they are really called at this moment. I painted the tag light black on the outside. Everything was going alone just fine until I ran into a snag. My bumper came in today. It was shipped in by UPS. Well the bumper box was damaged and the bumper was scratched. UPS is going to come out Monday and take a look see. I hope we can come up with something. So, now I am at a stand still again. No big problem, just another hurter to jump.
Check out Patches
Old 09-06-2014, 07:24 AM   #2003
colgad
colgad's Avatar
Re: 1968
Your square hole came out great. I was in a hurry when I did mine. Now after seeing yours I am taking mine out and cleaning it up. ( I needed to paint it anyway) Where did you get the style of plate that stays down? Local or ebay?
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 09-06-2014, 01:19 PM   #2004
gdavis
gdavis's Avatar
Re: 1968
I bought the rear bumper, backing plate, flip down and tag light from Brian in Ks., he switch from a step side to a fleet. A package deal, but he bought it from LMC The flip down can be mounted up or down what ever way you like. Or you can go to a bone yard and het one from a 1992 caprice. The square hole came out real nice. After I cut it out I took a file and smooth the rough edges and rounded the edges a little. then three coats of black
Check out Patches
Old 09-07-2014, 01:57 AM   #2005
gdavis
gdavis's Avatar
Re: 1968
I have been looking for the proper install on the rear bumper brackets. I thought they were straight with the frame. I found out later that they are suppose to be at a slight angle with the frame. I had to make a call to Ks. to get the right position of the brackets. So, now I am in line to install the brackets Monday. The brackets at a slight angle just didn't look right. But all the holes line up and there it is I don't know everything about these trucks.
Check out Patches
Old 09-07-2014, 10:04 PM   #2006
gdavis
gdavis's Avatar
Re: 1968
Got to repaint the tag bracket. The paint lifted,looks like a old mans skin. Older than me. I will have to sand blast the paint off I put on the tag bracket and then paint it again.
Check out Patches
Old 09-08-2014, 08:49 PM   #2007
gdavis
gdavis's Avatar
Re: 1968
I sand blasted the flip tag bracket today. Also painted it. it came out real nice this time. Don't know why the paint lifted, maybe some chemical was on it from the factory.
I mounted the rear bumper brackets/braces. They all line up like they should. Installed the front turn signal with new lens gaskets. I put the tail gate chain covers on also. I installed the interior rear view mirror it also is chrome. Did I say chrome will get you home. Well it will. Now I will have to wait for the rear bumper to be replaced. UPS will pick up the first one that was shipped to be tomorrow. It has a lot of scratches on it, so it has to be replaced by UPS.
Check out Patches
Old 09-08-2014, 08:55 PM   #2008
gdavis
gdavis's Avatar
Re: 1968
parts that came in today
Check out Patches
Old 09-08-2014, 08:58 PM   #2009
gdavis
gdavis's Avatar
Re: 1968
more pictures. Tomorrow, I need to put some washers under one side of the pass side turn signal. It looks a little un-even
Check out Patches
Old 09-09-2014, 08:14 PM   #2010
gdavis
gdavis's Avatar
Re: 1968
Today, I sanded the rear bed sill it was showing a little wear, like scratches. I did not like the way it looked. Then I painted it with raddle can black, now it looks a lot better. Removed the bumper braces and re-installed them with shorter bolts and new lock washers. 1/2 inches shorter bolts, now it don't look like I just used any bolts that I could fine. Nothing wrong with the bolts it just looked to busy. Put the final coat of paint on the tag holder.
UPS came by today and picked up the bumper that was damaged in shipment. Don't know how long that will take. I hope not too long. I want to rewire the truck this month and I would like to have the tank and bumper installed. I don't want anymore breaks in the wires than I can help.
Check out Patches
Old 09-10-2014, 09:50 PM   #2011
gdavis
gdavis's Avatar
Re: 1968
Today, I installed the 4 washers on the pass side front turn signal. Now the turn signal is level. It is amazing what a little love will do. Then I drilled the holes for the Camaro gas tank supports. I for got to take pictures so I will do so tomorrow. I removed the tail lights. Getting ready for a stainless set of tail lights from a fellow board member. Can't wait to see what they look like on MY truck. Still no word on the rear bumper.
Check out Patches
Old 09-11-2014, 07:11 PM   #2012
gdavis
gdavis's Avatar
Re: 1968
Well, here are the pictures of the supports for the Camaro gas tank. The front turn signal where I put three or four washers. Now it sets straight. I am a firm believer in pictures. I guess that is why I have 81 pages in my build. I still a way to go but, I now can see the rear door it is now open a little. Now, I am waiting on UPS for another bumper. It's the little things that take a lot of time on these builds. I made the tank supports to short. have to re-do the supports 1 whole day shot.
Check out Patches
Old 09-12-2014, 12:19 AM   #2013
gdavis
gdavis's Avatar
Re: 1968
Has anyone ever used chrome conduit for the tail lights for a step side bed. here is a picture of the conduit. I bought it from Classic parts and can't figure out where or how it attaches.
Check out Patches
Old 09-12-2014, 03:47 AM   #2014
Xeen
Xeen's Avatar
Re: 1968
Originally Posted by gdavis View Post
Has anyone ever used chrome conduit for the tail lights for a step side bed. here is a picture of the conduit. I bought it from Classic parts and can't figure out where it attaches.
Unfortunately I have no idea on this one George, I didn't even know it existed until you told me
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-12-2014, 08:38 PM   #2015
gdavis
gdavis's Avatar
Re: 1968
Today, I was bored so I thought I would get ahead of the tank and brackets. Every thing I touched turned to crap. Welded a bolt to the supports. I thought they looked real good, until I notice the supports were upside down. So I had to remove the welded bolt and turn them over and re-weld a bolt on each end. A whole day wasted. Tomorrow I will pick up some 3/8 all thread rod. This I will use on the tank straps on the rear of the tank. The only place that is not covered with my canopy is where I was working. The rear of the truck. The sun beating down on my back, so I had enough of that so I quit and went inside for a tall glass of green tea.
Check out Patches
Old 09-13-2014, 03:51 AM   #2016
Xeen
Xeen's Avatar
Re: 1968
George the truck is mobile, just move it so that you are working in the shade next time.
Old 09-13-2014, 09:20 AM   #2017
zicc1835
zicc1835's Avatar
Re: 1968
George,
just went thru your entire build thread WOW it would be an understatement to say nice work hope mine turns out half as nice as yours
Jess
zicc1835 is offline   Reply With Quote
Old 09-14-2014, 01:09 AM   #2018
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by zicc1835 View Post
George,
Jess
Thanks. I do try and sometimes I fail. again thanks. I thought the same when I looked at other guys trucks. But, the end result is what I go for, not the trip.
Check out Patches
Old 09-14-2014, 01:11 AM   #2019
gdavis
gdavis's Avatar
Re: 1968
it don't run so I would have to push it. No one to help push is a little problem. But I am working on a solution to this.
Check out Patches
Old 09-15-2014, 11:25 PM   #2020
gdavis
gdavis's Avatar
Re: 1968
today I dry fitted the Camaro gas tank. It looks good I will post pictures tomorrow with the right strapping.
Check out Patches
Old 09-16-2014, 06:55 PM   #2021
gdavis
gdavis's Avatar
Re: 1968
Today, I had another look at the Camaro gas tank supports. They would work but, it just wasn't clean enough. So I took everything apart and started again.
cut two pieces of 2 1/2x 2 1/2x1/8 square tubing 28'' long and bolted them to the cross members. I know the square tubing is a little over kill but, The welding shop didn't have the 2x3 that I wanted. I picked up two pieces of 1x1/8 36'' long aluminum. tomorrow I will make my straps.
well, back to square one on the rear bumper. UPS would not pay for the damages so the bumper was trashed. It was a shame for the bumper traveled from Ks. to Fl. and back to Ks. So in a few days I will order another one.
Check out Patches
Old 09-17-2014, 08:56 PM   #2022
gdavis
gdavis's Avatar
Re: 1968
Today, I mounted the Camaro gas tank. Made my strapping out of 1x1/8 inch aluminum
got it where it needs to be. Except I will have to move it forward a bit I think. I need the bumper to adjust that. I also mounted the tail gate and I used stainless bolts.
You can see black tape on the clear chain covers. If I did not put the tape it looked like a round ball. This way it can form to this shape. Let the sun do its magic.
Check out Patches
Old 09-18-2014, 08:22 PM   #2023
gdavis
gdavis's Avatar
Re: 1968
today. I wanted to put the cowl back on the truck. But, my next door neighbor's water pump went out. So I installed a new one for them. Maybe tomorrow.
Check out Patches
Old 09-19-2014, 11:53 PM   #2024
gdavis
gdavis's Avatar
Re: 1968
Well, I hope that the stainless tail lights and stainless tail lights brackets come in by Monday. They were shipped the first of the week from Ks.
also ordered a set of spray nozzles and a steering wheel. Hope to mount the spray nozzles and cowl one day this week. Again
Check out Patches
Old 09-20-2014, 10:10 AM   #2025
colgad
colgad's Avatar
Re: 1968
George, not sure how much this helps but here it is anyway. Can't find any washer nozzles but that does not mean I don't have any. I will keep looking.
