Running C10 Lower Control Arms With C20 Spindles
So I screwed up and misread that I could swap ball joints and run c10 lower control arms on a c20. Got the c10 joints pressed out and they c20s are nowhere close to fitting. Not sure how I didnt noticed that before I pressed them out
![]() Is there a ball joint that has the c10 cup size and c20 shaft size? Or a sleeve I can run to make a c10 joint work? Or am I SOL and need to look for some c20 arms? |
#2 | |
Re: Running C10 Lower Control Arms With C20 Spindles
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
I was going to call you on my lunch break today. What do you think about cutting the smaller cups off and welding a c20 cup on? The arms are cpp's and it looks like it could be done with a little jigging
#4 | |
Nate
Thanks for your help. I'll give you a call later today and either order some cups or some new arms
