Old 09-08-2014, 07:05 PM   #1
1974ChevyC30
1974ChevyC30's Avatar
Master Cylinder Keeps Blowing Rear Seal
Alright I have a reoccurring mystery that I can't seem to solve. I have replaced my master cylinder twice once was a remanufactured napa unit and the other was a brand new napa unit. The remanufactured one replaced the "original" unit that also blew a rear seal but lasted somewhat longer. Before I get into detail here is how long each lasted:
"Original": Unknown number of miles
Reman: 1 Night
New Napa Unit: 400 Miles
I have replaced everything in the brake system including: wheel cylinders, calipers, most of the lines, pads, shoes, etc... everything except the vacuum booster. Keep in mind this truck originally had a hydro-boost system from the factory(in 1974). The new unit blew right after I got my 454's compression back up with a intake/exhaust valve tweak and carb float adjustment(she runs real good now!). I'm at a complete loss why this truck hates the vacuum boost system so much that it keeps blowing master cylinders. Any advice or ideas?
1974ChevyC30 is offline   Reply With Quote
Old 09-08-2014, 11:36 PM   #2
SCOTI
SCOTI's Avatar
Re: Master Cylinder Keeps Blowing Rear Seal
Reman: 1 Night
I've experienced a similar situation.... Bad master cyl w/the oe hydro-boost. Swapped in a new unit & shortly after it started leaking @ the rear seal. At that time, I swapped to vac brakes when I swapped the leaky m.cyl. Then, that unit started leaking so I bought another.
So far so good but it's only been in place for a short period. I found it weird though that multiple units failed similarly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
blown seal, brakes, master cylinder
