Old 09-06-2014, 01:51 PM   #1
jamie72
jamie72's Avatar
98 interior door handle
looks like I need to replace the interior door handle on my 98, I have been having to jerk it harder to open lately, or is it something else? how much of a job is this going to be?
thanks
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-06-2014, 02:42 PM   #2
El conquistador
Re: 98 interior door handle
Common issue with these trucks. The metal cracks in the handle and you don't see it without removing it. Easily replaced and available at many auto parts stores.
El conquistador is offline   Reply With Quote
Old 09-06-2014, 06:52 PM   #3
BigBlocksRule
Yep, a whole lot easier than replacing the outside POS. Gremlins live inside those doors and slash and chop your arm and hands when you work on the outside handles, little buggers don't seem to mind when someone works on an inside one, though.
You will have to drill out the original rivet, I use a small wood screw to replace it.
O'Reiley's should have it, may have to order it in to get the correct color.
But by all means, jerk hell out of it and break the old one before you replace it, that somehow gives a little bit more satisfaction...
BigBlocksRule is offline   Reply With Quote
Old 09-07-2014, 05:28 PM   #4
68c10owner
68c10owner's Avatar
Need to do this to my driver door. I have to roll the window down to get out, pass side is hard for my daughter to open. Went on ebay and bought both sides in the correct color for $22. Not sure of the quality as I havent done the job yet but they look ok. There is a video on youtube from A-1 auto or something like that that shows how to do the swap. Looks pretty easy.
Anthony
68c10owner is offline   Reply With Quote
Old 09-07-2014, 08:45 PM   #5
jamie72
jamie72's Avatar
thanks guys,, kinda what I thought.. getting ready to order one.
jamie72
member #807
www.antlertalk.com
Old 09-08-2014, 07:17 AM   #6
BigBlocksRule
Use pliers to push the rods up out of the plastic "locks", don't just try to pull 'em out.
I use a modified long screwdriver to help get the door panel plastic whatchamacallems out, they break easily, so don't get in a hurry with those. Other than that, this is about as easy as a repair gets. I've used parts store and ebay replacements, haven't broken either since replaced. Why GM thought pot metal would work fine for door handles is beyond my comprehension...other than the replacement parts cash cow...
Old 09-08-2014, 01:53 PM   #7
El conquistador
I'd order a bag of these before I started.
Amazon.com: 50 Door Panel Push Type Retainers GM... Amazon.com: 50 Door Panel Push Type Retainers GM...
Those clips break easily and it's much cheaper than going to the dealer.
Old 09-08-2014, 02:43 PM   #8
BigBlocksRule
Yeah, and don't try to pop 'em off, you can break the door panel place that holds the retainers. I keep a junk one on the wall of my shop, spray painted all the retainer spots bright pink, helps to know exactly where they are, prevents breakage.
Old 09-09-2014, 06:47 PM   #9
legendman
legendman's Avatar
I got the one in this pic on epay for $10.34 with shipping
Hopefully it lasts a little while
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 09-09-2014, 07:33 PM   #10
pwdcougar
pwdcougar's Avatar
I've done the drivers door on my 97 3 times already. Not a difficult job at all.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-09-2014, 07:37 PM   #11
BigBlocksRule
Your epay was probably cheaper than local autoparts store for the identical item.
Old 09-09-2014, 09:05 PM   #12
pwdcougar
pwdcougar's Avatar
If the part is original Chevy hopefully it will last longer. My original lasted 9 or 10 years and the aftermarket ones about 3 each! They are so common though you can find them in the HELP section of some parts stores.
Paul
