Brake warning light on after brake job??
I'm a rookie to drum brakes. Seems like all the trucks I've owned have all had new rear brakes. However, my burb does not. So, I put new shoes, wheel cylinders, and spring kits on the rear today. I also had the drums turned.
Anyway, now my brake warning light is on. Is this probably just an adjustment problem? I tried to get the hubs on there snug using the adjustment piece at the bottom, but maybe not. I also bled the rears again to see if that was the problem, but that wasn't it. That brings up another point, whats the procedure you guys use to bleed the brakes? I had someone pump the pedal several times and then he held the brakes to the floor and then I opened the valve until there was no more spitting. However, it seemed logical to me that fluid should still have been coming out as he was holding it to the floor until I closed the valve. However, it didn't. Thanks!
Scott Shelbourne |
Holding the brake to the floor and no fluid comes out?
Something's blocking it then. Perhaps a collasped brake hose or two? Too much crud in the system? |
#3 | |
Scott Shelbourne |
Did the master cylinder go empty anytime you were doing this?
Well, it did get really low. Not sure if it went empty or not. I did fill it back up.
Scott Shelbourne |
Robert Olson Transport
![]() Join Date: Oct 2002
when youre bleeding the brakes yes the flow will stop. What i do is start at the furthest wheel ( Back right) and have someone pump and then hold after four to five pumps then i loosen the bleeder. it will spit out and stop. then i tighten the bleeder. yell pump and the guy pumps the brakes again he pumps three or four times and holds it again ya loosen bleeder and the fluid will spurt out and stop. You then check the master to see how low it is and add as necessary. You know youre done bleeding brakes when #1 the pedal remains firm when you pump it after that and ya let go and when your ebleeding the brakes the frothy air laden fluid doesnt come out when you release the bleeder.
If you let the fluid out of the master youve got alot of bleeding starting with the master through the whole system also if the rubber lines are old and cruddy you may have to replace them. also did you get the adjusters adjusted properly so that the shoes are not having to travel too far to the drm that would make the lite come on tooif ya need further help let us know
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
#7 | |
Scott Shelbourne |
Gentleman Jim Driver
The brake warning light comes on when the shuttle valve in the proportioning block moves. It's there to prevent a total loss of brakes when either the front or rear system gets a leak. When you are bleeding brakes, it looks like a leak to the shuttle valve and it goes from it's normal mid position to one end or the other. This happened to me when I rebuilt the rear brakes on my 87 but while I was in reading about it, it shifted back on its own. Vigorously bleeding the front brakes might shift it back too.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#9 | |
Scott Shelbourne |
dont over adjust the rears tho the way i usually do it is make em tight enough so there is a slight bit of resistance when you try to slide off the drums. now ifyour drums are old and havent ben resurfaces you may have a lip there which makes it harder to check .
Some of those had a reset button that was used when the resivoir got low enough and new fluid was bleed thru the system....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
72 gm service manual says
The combination valve, located near the master cylinder, must be held in the open position while bleeding. This can be accomplished by installint Tool J-23709 with the open slot under the mounting bolt and pushing in on the pin in the end of the valve. I guess if you don't have this tool you could have a third person hold in the pin with a screwdriver or something. Hope this helps. |
30+ years ago an old mechanic showed me an alternate way of adjusting drum brakes. Get the slot aligned with the star wheel, adjust the brakes out until you just barely can't turn the drum by hand, pump the pedal to center the shoes, then make sure you still can't turn the drum. Tighten more if necessary. Then stick something (thin screwdriver, ice pick, etc.) through the slot to hold the adjuster off the wheel, & adjust the wheel 3 to 6 notches looser as needed. The Chevy place I worked at back then used the "back up real fast & pump the pedal" method, but they had a big parking lot to do it in.
Stylin
thats the ebrake light right? if its that, then the drums are self adjusting, back up and stomp the brakes the repeat a couple of times then stomp the ebrake then release and it should go off if it hasnt already thats how i get mine to go off
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
#15 |
Thanks guys! Actually, I resolved this problem by simply bleeding the front brakes after bleeding the rears. Guess that moves something in the proportioning valve back.
Scott Shelbourne |
