Old 09-09-2014, 03:32 PM   #1
MikeS.
MikeS.'s Avatar
Need some help with a 63 Grill.
My 63 Burb came with a 64- 5–6 grill. Does anyone know if the brackets that attached to the grill and to the front of the truck are the same across the years?
This piece
It doesn't look like it to me but before I start tearing the old grill apart I thought I would ask.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 09-09-2014, 03:45 PM   #2
1963c-10
1963c-10's Avatar
Re: Need some help with a 63 Grill.
Not sure if the backing plates will work.....60-61 had dual headlights...so different buckets entirely. 62 was single but had 3 bolt mount.... 63 was a 4 bolt per side mount and pretty sure 64-66 were 3. I know the headlight buckets and internal hardware will work though.
1964 Short bed trailer
Old 09-09-2014, 07:54 PM   #3
Jurassic-1
Jurassic-1's Avatar
I think it will be fine. My 66 had a 1962 grill on it when I got it and I had no problem changing it.. Worst case you could make a template and drill new holes.
Jurassic-1 is offline   Reply With Quote
Old 09-09-2014, 08:02 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
FYI the original 63 supports are stamped SAE-63. I got a set off a guy in Northern Michigan. With all the 63 grills you see that are crushed and of course missing at least 1 headlight bezel, someone must have the supports to sell.
Old 09-09-2014, 08:13 PM   #5
60-66
60-66's Avatar
Mike, a 1963 grille "bracket" actualy called a Support and is riveted to the grille is one year only. It was made to fit the 63 grille and does not fit any other year.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-10-2014, 12:51 AM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Ask Rene the "C10 King" he always puts the 63 in his trucks. So I'm sure he has a clue to give you an educated answer. I'm looking forward to meeting you in A****er this year and seeing your Burb.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
