#26 | |
Re: Previous Owner Funtime
#27 |
![]() Join Date: Mar 2014
The po of my 68 installed a fuel tank from a square body in the bed to bypass a non existant problem with the in cab tank - which apparently he didn't know was brand new. I removed that tank replaced the 5/16, 3/8 fuel line mess and rebuilt the toilet edelbrock calls a carburetor and problem solved.
http://67-72chevytrucks.com/vboard/s...d.php?t=620707 |
#28 |
The previous owner of mine replaced the rockers and cab corners with generic pieces losing the lower body line...at the moment a rust free cab is the easiest and quickest fix.
1965 SBFS BBW Soon to be Restomod Daily Driver 1972 Chevy Nova-Pro Touring |
#29 |
Some good stories in here. I worked as a mechanic for 20 years and have seen some pretty crazy things. We used to say "he knows enough to be dangerous". Lots of the fixes were safety hazards, and potential fires or accidents. One of my biggest peeves is those little square blue wiring connectors that snap together with no splicing needed. They are an invitation for corrosion. I bought a NEW enclosed car trailer a while back, and the whole thing was wired with those connectors. I had a couple of inches of an ice cream pail full of those connectors that I had to remove. I had to solder and shrink tube every single connection. Lots of panels to take off to get access. A couple years down the road the whole thing would have to be rewired. Whoever invented those connectors should be lined up against a wall and shot with a ball of his own s#*&. I see lots of them under the dashes of old vehicles. Drilling holes in dashes really drives me too.
#30 |
Resident Photoshop Nerd
I suppose a beat to [bleep] body that had a 400 block with a 283 intake, and inflate-it-yourself air-shocks in back, isn't so bad after all that I've read. xD
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn |
#31 |
Here are a few pictures. I wanted to get some of the truck with the firewall hole and torched engine mount perch, but all the wasp nests and poison ivy deterred me. I think you guys will still appreciate the ones I got.
#33 |
Wow. 66submarine you have the best bad examples I have ever seen. I can't decide which picture is the worst, there is some really scary stuff there. Makes you wonder what else you are going to find. My god.
#34 |
Thanks.
![]() ![]() I have an 11" brake drum that measured out @ something like 11.250-11.300" that always amuses me--not a lot of meat left on that one! ![]() |
#35 |
One of my PO's tried to bondo the famous A-pillar problem and failed. Put flame decals on it when it was still white and then painted it green with a white top (house paint mind you and did a very s****y job of laying the paint.) and never removed the decals, you can still see the driver's side flames through the paint and i found a set on the rear right fender 2 weeks ago under the grime while washing my truck. Also broke a heater control lever off in the dash. Also they bent a connector pin on the firewall connector for the lights when i tested my bright to find out they didn't work.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie. |
#36 |
66Submarine wins, I never seen anything like some of that stuff. My truck was in pretty good shape, only had the wrong motor mounts (I think they were the original V6 mounts so they added some 1/4" steel plate, drilled some new holes and viola custom fit mounts for a small block V8. All it needed then was a couple of pieces of chain and the engine was in solid.
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
#37 |
![]() Join Date: Jun 2013
I feel everyone's pain, electrical issues just seem bring out the best of the worst hacks, but bodywork is right there too. On my 51 GMC the PO did some awesome work on the floors. He pop riveted a bunch of sheet metal on the floor pans, left the original battery in the floor under all this crap, and the icing on the cake was to take a large carpet mat and turn it rubber side up and rivet it down for a "factory looking" rubber floor mat. The problem with this the carpet held water on the floors and turned what was most likely a small rust problem at the time into a complete floor replacement.
