OEM tach with V8???
I'm planning on putting a SBC in my '71 C10 that has an OEM tach and a 250 6cyl.
Will the tach work correctly with the V8? |
![]() Join Date: Apr 2010
Re: OEM tach with V8???
No, you have to get the v8 tach. If it is a factory 6 cyl tach they are kind of rare!
Yes it is factory according to former owner. Is it something I should trade for or is the 6cyl version worth alot more because of it's rarity?
1st of all you should find out that it is a 6cyl tach. When you remove the cluster from your truck, the tach will have 6cyl or 8cyl on the back of the tach. I have 5 or 6 factory 8cyl tachs and if you decide you want an 8cyl tach I will trade one of them for your 6cyl tach
Thank you.
Since it is working fine with my 6 cyl., right now and there are separate tachs for 6s and 8s, wouldn't you assume it is a six? Thanks |
#6 | |
![]() Join Date: Apr 2013
If it is a 6 cylinder tach I'd be interested in buying it.... |
#7 | |
I'll have to wait until I take it off, but my feelings are that it is running very close to what it reads....but I could be wrong! Thank you |
Moderator
![]() Join Date: May 2007
This is not the parts board. Please do not turn this into a for sale thread or it will be locked. Thank you.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
My only interest was to find out if I can use the tach I have with a V8. I suppose I got my answer by finding out that the tach is marked on the back and until I take the dash apart, I will not know what I have.
Roadtrip!
![]() Join Date: Feb 2003
If it reads accurate now on your 6 cyl, thats what it should be. You will need to hook up another known accurate tach (hand held maybe) to determine that if you don't want to pull it right now.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Jun 2011
could you use the rpm reading off a dwell meter?
#12 | |
Unfortunately the whole truck is apart right now to replace rockers, corners, supports etc and the tank is out.
I guess I'll have to check back of tach after engine and body work is complete. I know the engine is not running 667 RPM but I'll confirm everything later. Thanks |
Ok, after a few setbacks, the project is back on.
Took dash cluster out and looked behind tach, there is no indication as to 6 or 8cyl. There is just a marking of 12 volt. |
#15 |
67-72 parts collector,…
![]() Join Date: Nov 2002
The marking will be really faint.
Not physically stamped into the back,... more of an ink mark stamp.
#16 |
The Older Generation
As Keith said, It would be stamped in black ink and sometimes it is very hard to see. Here are a couple of threads on 6 Cyl tach values. Just remember these are older threads so value may have increased. http://67-72chevytrucks.com/vboard/s...d.php?t=511414 http://67-72chevytrucks.com/vboard/s...d.php?t=514671 LockDoc
#17 |
Cluster King
![]() Join Date: Nov 2012
If you need help with your tach, please let me know. I have a tach calibrator that will not only tell me if your tach is a V8 or a 6 cyl but also calibrate it so that it is right on the money.
One thing to note is that a V-8 factory tach cannot be calibrated to work for a 6 cylinder. One thing you can also do is find a timing light that reads RPM like a Snap On does and compare it with what you have. Let me know if I can help. I specialize in complete gauge cluster repair, restoration and parts. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#18 |
Not really trying to sell it unless I can't use it if it is an original 6cyl. Can't find markings
, I'll try to look harder, |
#19 |
Since you really can't read them fine enough to do a proper tuneup, I ordered a low-rpm tach from Amazon. It looks like the old Sunpro units but its super cheap - and made like it. It has scales for 6 cyl and 8 cyl (and 4 too I think) so you'd be able to just compare what it says and see which scale it matches.
If its a 6 cyl you could probably trade it for two 8s, or sell it. Who would have ordered a tach with an inline 6? Truck guys I suppose, surely not a perf concern. But for guys with 6 bangers I imagine the factory tachs are hard to find. And probably not reproduced so far as I remember. Under $30: ![]()
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
