Old 09-13-2014, 10:48 AM   #1
mandojunior
Smile 69 short stepside build
hey guys! i had a thread titled new here, 69 longbed build. i changed direction shortly after i made it. i bought a short frame with a stepside bed and disc brakes all around. you can find the previous work here. 67-72chevytrucks.com/vboard/showthread.php?t=602406
i will be updating this thread now. next on my list is putting my motor back on, fixing my rocker and cab corner and bed. ill post pictures soon
mandojunior is offline   Reply With Quote
Old 09-15-2014, 01:48 PM   #2
mandojunior
Re: 69 short stepside build
started doing some rust repair on my door. im in the process of filling in the mirror holes right now
Old 09-15-2014, 01:50 PM   #3
mandojunior
patched up
Old 09-15-2014, 02:02 PM   #4
mandojunior
peep mirror and mirror holes filled in
Old 09-17-2014, 01:21 PM   #5
mandojunior
heres a quick recap of what ive done to my truck
Old 09-17-2014, 01:25 PM   #6
mandojunior
heres when I first bought it and then when I started tearing it apart.
the stepside at the end is the parts truck I bought. it had front and rear disc brakes.
Old 09-17-2014, 01:29 PM   #7
mandojunior
I removed the rocker panel and cab corner. I still haven't welded the new ones in. I sandblasted and painted the motor and just recently hooked up all the brake lines
Old 09-17-2014, 01:35 PM   #8
mandojunior
I sandblasted and painted my rear disc brakes but when I tried to put the wheels on the studs aren't long enough. they only get about a quarter inch. does anyone know who makes or have a part number for a longer wheel stud?
Old 09-18-2014, 09:56 PM   #9
mandojunior
i finally dropped my motor in.
Old 09-25-2014, 12:31 PM   #10
mandojunior
i bolted up the transmission this morning. I made a custom transmission mount, all i need is to weld the tabs that hold it up and ill be able to move it outside for a wash
Old 09-25-2014, 10:34 PM   #11
mandojunior
i put in the transmission crossmember and starter.
Old 09-25-2014, 10:37 PM   #12
mandojunior
while i was working on the transmission my dad got to work on the cab corner and rocker panel.
Old 09-25-2014, 10:41 PM   #13
mandojunior
he started by brushing on a rust converter from eastwood, after grinding off the rust. then welded the rocker followed by the cab corner
Old 09-26-2014, 10:55 PM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
Call Moser about the wheel studs - www.moserengineering.com
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-26-2014, 11:23 PM   #15
mandojunior
i just looked them up. i wish i woulda known about them 3 days ago when i ordered some doorman studs. they're the same price and the moser ones are much longer
Old 09-30-2014, 12:38 PM   #16
mandojunior
i got my cpp drop spindles put on last night
Old 09-30-2014, 12:42 PM   #17
mandojunior
i cant remember what this line that was hooked up to the transmission went to. anybody got a clue?
Old 10-02-2014, 12:20 AM   #18
BossHogg69
motor exploder
BossHogg69's Avatar
if the line in your hand runs to that little canister on the passenger side of your transmission, that is your vacuum modulator valve hookup. It should connect to a manifold/unported vacuum source (below the throttle blades) of your carb. You can connect it right on the manifold with an NPT to hose barb adapter or on the baseplate of your carb if you have a corresponding nipple on the baseplate of the carb.
Adam
Old 10-02-2014, 12:50 AM   #19
Xeen
Xeen's Avatar
I really like the dark blue paint you used on the engine, nice touch.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-02-2014, 01:01 AM   #20
mandojunior
thanks! when i sandblasted the manifold i remember taking a barb off right under the carb
Old 10-18-2014, 09:51 PM   #21
mandojunior
i havent been doing much to my truck lately. been busy with other stuff but i made a drive shaft since my two piece one wasn't going to work. i tested it n it fits good, i just gotta go get it balanced
Old 10-21-2014, 10:45 PM   #22
mandojunior
so i put in the new exhaust manifolds today
Old 10-21-2014, 10:49 PM   #23
mandojunior
i also cut my exhaust pipes and left them ready to weld tomorrow
Old 10-31-2014, 11:51 AM   #24
mandojunior
well i still havent welded the exhaust, been busy doing work around the house but i did paint my engine brackets and fan and put them on
Old 10-31-2014, 04:23 PM   #25
mcbassin
Still Learning
mcbassin's Avatar
Nice looking project mandojunior. I hope to get the chance to see it in person some time. I'm just east of you a bit. Subscribed...
