Old 09-14-2014, 08:36 AM   #1
Bean Counter
Steering Column Mount to Dash??
I need help AGAIN! I've started trying to re-install my steering column. No problem with the firewall mount but I've gone totally brain-dead on the dash. I have the two metal brackets that bolt up to the bottom of the dash, one underneath and the one where the instrument panel is - but even after tightening these the column is sitting loosely at least 1/4" to 1/2" below the rounded fitting in the dash. Of course, I didn't take pics when I pulled it out so I can't remember if there was another piece that helped sandwich the column securely between those brackets and the dash. Any help - pics or otherwise - would be greatly appreciated!
Thanks,
David
David
Next project - 1953 Chevy 150 2 Dr Sedan.
https://www.chevytalk.org/fusionbb/s...hp?tid/355913/
Bean Counter is offline   Reply With Quote
Old 09-14-2014, 09:13 AM   #2
1972BlueC20
1972BlueC20's Avatar
Re: Steering Column Mount to Dash??
Do you have the black rubber donut piece that goes around the column and fills the gap between the column and where it touches the cutout in the bottom of the gauge cluster bezel?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 09-14-2014, 09:22 AM   #3
70shortfleet
70shortfleet's Avatar
Take a picture and show us what you have
70shortfleet is offline   Reply With Quote
Old 09-14-2014, 09:52 AM   #4
Bean Counter
Here are some pics of what I have. I took everything apart about 5 years ago and THOUGHT that I had bagged/tagged everything. Apparently, my organizational skills are on par with my powers of recollection. Apologies for the pics being oriented wrong.
David
Old 09-14-2014, 05:55 PM   #5
70shortfleet
There is a U shaped bracket that is above the large square bracket that has the rubber stop pad for your brake pedal. That is the bracket that holds it tight, is that bracket there?
Old 09-14-2014, 06:02 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Steering Column Mount to Dash??
You have to take the brake stop plate back off and the black trim piece. Look under the dash above the square brake plate. A u shaped bracket goes around the column and bolts into the under side of the dash.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-14-2014, 09:53 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Here are the brackets you should have....
LockDoc
Leon
Old 09-15-2014, 05:36 AM   #8
Bean Counter
Thank you all! It's the bracket on the left of Lockdoc's pic that I've misplaced - but since I never throw anything away I know it has to be around. And now that I know what it looks like, the search will be much easier.
I really appreciate the help.
David
David
Old 09-15-2014, 01:38 PM   #9
LockDoc
LockDoc's Avatar
David
Let us know if you don't find it....
LockDoc
Leon
Old 09-28-2014, 08:20 AM   #10
Bean Counter
Thanks for the help everyone. I FINALLY located a spare bracket on the pedal assembly from a donor cab . Haven't found the original bracket yet. When I do this again, I'm going to take a picture every time I breathe and have a separate, labelled box for every assembly.
David
David
Old 09-28-2014, 10:51 AM   #11
LockDoc
LockDoc's Avatar
David
Glad you got it together. I used to take all kinds of pictures but I have had so many of them apart over the years that I don't need to do that any more....
LockDoc
Leon
Old 09-28-2014, 05:06 PM   #12
57taskforce
All about them K’s
57taskforce's Avatar
Where does the black piece go? I bought my truck with the column hardware missing and I've acquired the plate and u strap but have not seen the black plate till now. If someone could post a pic of it all together that would be awesome!
Tyler
Old 09-28-2014, 09:21 PM   #13
LockDoc
LockDoc's Avatar
I don't have a pic but after all the other pieces are bolted on this goes under the dash and the "U" shaped part fits up around the rubber collar at the instrument panel....
LockDoc
Leon
Old 09-29-2014, 01:08 PM   #14
57taskforce
All about them K’s
Ok. Thanks for that. Putting together what someone else took Part with all pieces missing can be challenging. If any one has a pic that would be great.
Tyler
Old 03-16-2016, 09:39 PM   #15
lawest
This site is amazing! The exact thing happened to me and I found this thread with a search for 'steering column mount'. Great information even though it was 2 years ago.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 03-17-2016, 10:23 AM   #16
snipescastle2
snipescastle2's Avatar
Talking Re: Steering Column Mount to Dash??
I feel your pain! Try putting together a complete "Basket Case" I literally, had to put every single piece of this truck back together, and what was missing or damaged (not very much) I searched for good used parts where I could find them, or settled for some small repro parts.
I'm hoping to fire it up tomorrow for the first time! I still have to install the bulk of the exterior
trim, and the door windows/door panels, but, I have my priorities!
Have a good one!
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 03-17-2016, 12:16 PM   #17
30 a truck
30 a truck's Avatar
I ask the same question about 2 months ago. My truck was completely disassembled when I bought it. PO just threw everything in boxes, nothing labeled or marked in any way. This gang sure helped me start to get mine back together.
30 a truck is offline   Reply With Quote
Old 09-27-2016, 10:30 PM   #18
justin_nelson
Sorry for reviving old thread......Are these brackets year specific or are they same across the board for 67-72. Also, are they the same for auto vs 3 speed on column? I have a 68 3 speed on column and I have located some brackets off of a 71 auto. Will they work?
justin_nelson is offline   Reply With Quote
Old 09-27-2016, 10:53 PM   #19
LockDoc
LockDoc's Avatar
No they are not all the same. The '67 and '68 brackets are different because the emergency brake handle bolts to the bracket in those two years. The '69-'72 are all the same and the only difference as far as the transmissions would be that the automatic pedal stop bracket would have one rubber pedal stop pad and the manual would have two. You can't see the rectangular holes for the rubber pads in the picture.
LockDoc.
Leon
Old 09-27-2016, 10:59 PM   #20
justin_nelson
Ok. Great. Thank you for your help!
Old 09-27-2016, 11:43 PM   #21
LockDoc
LockDoc's Avatar
No problem.
LockDoc
Leon
Old 04-12-2017, 09:02 PM   #22
Theboatandcarman
LockDoc
ok. the only bracket i do have is the one on the left! any mounted up photos please?
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094
2017 GMC Canyon diesel
1968 Chevrolet C20
1970 Mercedes 280S
(WTB 1968 4wd barn door suburban)
Theboatandcarman is offline   Reply With Quote
Old 04-12-2017, 09:35 PM   #23
El Dorado Jim
http://67-72chevytrucks.com/vboard/s...unts+installed these are all the pieces you need
El Dorado Jim is offline   Reply With Quote
