Re: 700R4 build thread.
1-2 Accumulator
Inspect Accm. Piston for Pin wear. Inspect Pin for wear. Inspect Accumulator Housing for wear. Install new seal on Accm. Piston. '82-'92, Install Piston in bore with "legs" up, Then Spring. '93, Install Spring in Bore, Then Piston with "Legs" Down. The '82-'92 Stack-up produces a later...Firmer 1-2 shift. The '93 Stack-up produces a earlier...Softer 1-2 shift. |
| Bookmarks |
