#2026 |
PROJECT 7DEUCE
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Very nice whats the eta on outside paint?
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#2027 |
![]() Join Date: Aug 2005
Depends if I decide to take it home to do the exterior body/paint-prep myself. I'm considering it because the cost is getting out of control... (not saying he's not worth it).
#2028 |
![]() Join Date: Apr 2005
I'm sure you will do a good job if you decide to go that route.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#2029 | ||
![]() Join Date: Nov 2004
![]() Quote:
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#2030 |
BlahBlahBlah
Nice! Is the outside going to be one color, or two toned? I probably missed it somewhere, but did you have all the exterior chrome work redone? Maybe it was already good?
#2031 |
Still planning to go with the same two/three tone --> Black top and red in the trim.
Trim/chrome work is good enough (gotta draw the line somewhere )
#2032 |
A few parts to join the mix:
![]() Killian does the honors of letting it touch the ground for the first time in 1.5 years: ![]() In case you guys lost touch with how small it is (I did! ) ![]() ![]() ![]() ![]() ![]() ![]() More scale perspective: ![]() Ready for the real bodywork to begin!
#2033 | |
I know the pieces fit
I've read this build twice now and thought I was subbed for updates but missed this one. Beautiful vision and execution. I like the blue you picked out, can't wait to see it on the car.
#2034 |
maibe you can brush all the brightwork
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#2035 |
Still Learning
Blue paint looks great. Looking forward to the exterior getting painted too.
#2036 |
Man! That looks good! Not to muddy the waters, but I saw my first Sunbeam Alpine on Saturday. All I could think of is That guy's Hillman will take it!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#2037 | |||
Interesting idea. Might have to look into this. Quote:
So the common tiger has a pounds/hp ratio of 16. Driftbeam will have 9. That Alpine you saw left the factory with 26.5. |
#2038 |
Think about that lb/hp when you read this ->http://www.windingroad.com/articles/...nder-40000/#10
#2039 |
BlahBlahBlah
Im so glad you went with those wheels ... they look great!
#2040 |
I love how they look on it too. But if I'm honest, it was pure dumb-luck that they worked out so well. They were hand-me-downs from the burb! I got them from a friend who had them on a 2003 Mustang. More dumb luck: Ford 5x4.5 = Honda 5x114.3
#2041 |
Speaking of wheels, I'd like to find some 17" steelies to use during the body/paint work (must be 17" to clear the brakes). Ideally something decent enough that later I can adapt the original hub caps and run them when I'm feeling the OG vibe.
So far it seems Crown Vic steelies might be the best option at 17x7.5. Anything with a 5x4.5" or 5x114.3mm you guys can suggest I'm all ears. |
#2042 |
double post removed
#2043 |
Can't wait to see it all done!
-Christian '91 318IS AW2 on black slow daily build 1Bad37: C5 Corvette Meets '37 Chevy |
#2044 |
What is the black you sprayed on the interior?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#2045 |
Interior is black SPI epoxy. Dash and trans tunnel will be blue. Just did the interior seam sealer in black over the black epoxy. Turned out really clean.
#2046 |
Testing out the cast coat aluminum on the oil pan. Will satin clear in 7 days.
#2047 |
I am blown away by this project, and your dedication to finishing it after all the time involved, so many times we see "projects" for sale because the builders lost the drive to finish. I am another Rootes group devotee, in my case a 1969 Hillman Hunter that I have owned for nearly 30 years, the current rebuild started in 2001, I swear I will finish it this year!
Max |
#2048 | |
Still Learning
#2049 |
I'm not certain if this is his reason, but I've seen a few different paint manufacturers say the window for putting on another coat of color, or clear, is pretty small (could be from 15 minutes to a few hours). If you miss that window, you have to wait 7-10 days before the entire coat(s) cures. Otherwise, there is a high possibility of wrinkled paint. I've had it happen to me with spray paint by waiting an hour.... not fun sanding it all back off to recoat.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#2050 | |||
That's exactly right. Recoat within small window (like 30min I think), or after 7 days. I too have made wrinkles ...no cool.
| Bookmarks |
