Old 09-16-2014, 11:46 AM   #1
SeTx67
SeTx67's Avatar
Doug Thorley header?
Does anyone happen to know at what angle the flange from the collector is at in relation to the frame? I have the 1 7/8" headers. I'm at work and away from home for several weeks and wanting to order some pre-bent exhaust piping so I can get my exhaust done next time I'm home. My goal is to keep the exhaust tucked up inside the frame rail for clearance reasons since my truck is low. Thanks in advance.
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 09-16-2014, 01:47 PM   #2
Clyde65
Clyde65's Avatar
Re: Doug Thorley header?
I believe the headers will dip below the frame rail by a tad, maybe an inch I believe.
OK, I lied.
here is a post...
http://67-72chevytrucks.com/vboard/s...d.php?t=287231
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-16-2014, 06:38 PM   #3
SeTx67
SeTx67's Avatar
I had seen that thread before but it only talks about the dt's with 1 5/8" primaries. Mine are the 323c-y with 1 7/8" primaries
Old 09-17-2014, 08:56 AM   #4
Clyde65
Clyde65's Avatar
have you contacted the rep with DT?
Clyde65
Rebuild of Clyde
support our troops!
Old 09-17-2014, 12:33 PM   #5
Hart_Rod
Hart_Rod's Avatar
I don't know the exact angle, it's pretty tight, but you can keep the exhaust above the frame rails.
Hart_Rod is offline   Reply With Quote
Old 09-17-2014, 01:01 PM   #6
SeTx67
SeTx67's Avatar
No I haven't. I think it may be best to have some patience (which isn't my strong suit ) and wait until I get home and put a angle finder on it.
I was hoping you'd see this thread. Thanks for the pictures. Any pics of the back half? Did you do 2 1/2 true duals, x-pipe or h-pipe?
Old 09-17-2014, 01:40 PM   #7
Hart_Rod
Hart_Rod's Avatar
Electric cut-outs with 2.5" duals all the way to the back.
Old 09-17-2014, 02:18 PM   #8
SeTx67
SeTx67's Avatar
Awesome! Thanks for the pictures
Old 09-18-2014, 01:31 PM   #9
DLW
Off subject, but I need a driveshaft like that. Did they make that custom for you based on their Camaro DS? I too have a 2014 L99/6L80E and converting to LS3 but haven't figured out how to attach a DS yet.
DLW is offline   Reply With Quote
Old 09-18-2014, 02:31 PM   #10
Hart_Rod
Hart_Rod's Avatar
Your welcome.
I had the Drive Shaft Shop build it for me.
Old 09-18-2014, 05:24 PM   #11
DLW
Thanks man!! I'll call them when I have some measurements..
Old 09-18-2014, 05:52 PM   #12
Hart_Rod
Hart_Rod's Avatar
Frank is who I spoke to. I would call him before I measure.
