Old 09-17-2014, 03:46 PM   #1
nsb29
nsb29's Avatar
6l80e drive shaft ?
I have a 6l80e from 09 G8 I wont to run a one piece driveshaft I have heard I could use a 400 bolt on yoke and have it machined to replace the 3 bolt flange looking for some input or a better idea thanks doug
nsb29 is offline   Reply With Quote
Old 09-22-2014, 05:16 PM   #2
nsb29
nsb29's Avatar
Re: 6l80e drive shaft ?
Originally Posted by nsb29 View Post
I have a 6l80e from 09 GTO I wont to run a one piece driveshaft I have heard I could use a 400 bolt on yoke and have it machined to replace the 3 bolt flange looking for some input or a better idea thanks doug
hasn't anyone run into this three bolt flange ??
Old 09-22-2014, 07:51 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yea, but we've steered away from it (and probably done the same for others). Yes it can be done, and has been done, but I think the general cost and time involved makes most folks look for another source vehicle that came with the "normal" connector.
You may have better luck finding a more in-depth explanation over on LS1tech. I have seen this however: http://www.shop.gforce1320.com/product.sc?productId=354
Its designed to bolt a regular driveshaft into a GTO with a tranny swap.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-23-2014, 12:44 AM   #4
DLW
You can check out this guys build, not the cheapest route but it did bolt right up that 3 bolt flange. http://67-72chevytrucks.com/vboard/s...358692&page=46
DLW is offline   Reply With Quote
Old 09-23-2014, 09:40 AM   #5
nsb29
nsb29's Avatar
thanks I knew someone had a better idea. adapter like this was my first idea br3w city gave me a link to a driveshaft manufacturer thank you both doug
Old 09-23-2014, 11:08 AM   #6
DLW
Just another link, these are the guys that built the one for Hart_Rod in his build http://www.driveshaftshop.com/
Old 09-23-2014, 12:47 PM   #7
nsb29
nsb29's Avatar
thanks doug
Old 09-25-2014, 10:23 PM   #8
clinebarger
Running a Machined TH400 bolt-on yolk & a drive shaft with a incorporated HD slip yoke is the ticket, The Machining is simple, And you have the G8/Camaro Yolk to take to the machinist.
Yolk, http://www.ebay.com/itm/Transmission...-/130322434555, This is Cheap! Is has a Spicer part# but not sure if it is Spicer or not.
DriveShaft, http://www.dennysdriveshaft.com/p136...lip.html#photo.
I also recommend a 1350 Yolk for the rearend as well to make the U-joints the same.
clinebarger is offline   Reply With Quote
Old 09-26-2014, 08:49 AM   #9
nsb29
nsb29's Avatar
I have the yoke, but the local machine shops I have gone to say they cant chuck it up or don't want to ??
Old 09-26-2014, 01:06 PM   #10
DLW
You could always use that driveshaft with slip yoke clinebarger posted and this flange http://www.driveshaftshop.com/drives...nger-05-06-gto.
This would be easier than converting your transmission from your 3 bolt flange to a slip yoke style to use a TH400 yoke or the 6l90e 1410 yoke.
Old 09-26-2014, 08:00 PM   #11
clinebarger
They just don't want to!! You can Bolt the Yolk to a Lathe Flange, Then Dial indicate to get out the run-out.....Then go to town!!
I'm an amateur with a Bridgeport Lathe, But even I know how to do this.
Great find, Yes that would be easier! I would put a Dial Indicator on it to make sure there is No Run-Out. Not putting down their work at all, But anytime you use a aftermarket "Adaptor, Add-a-Piece" it needs to be checked.
The next conversion I do with a car 6L80E, I will try this adaptor....Thanks DLW.
Old 09-26-2014, 09:55 PM   #12
nsb29
nsb29's Avatar
grate info I like the idea of turning down the 400 yoke because its less parts, but the adapter looks easy
Old 09-28-2014, 01:56 AM   #13
DLW
Let me know how it goes if you do it before me and vise versa if I do it first. I'm either doing this adapter with the Denny's DS you posted, or the DS Hart_Rod had made, not sure yet, at least there is a few options.
Now if they made more than one stand alone 6L80E TCM controller ..I was bummed when I called Mast Motorsports that had this working with their PCM to find out they quit on it and don't offer it.
Old 09-26-2014, 11:11 PM   #14
Hart_Rod
Hart_Rod's Avatar
My driveshaft uses an adapter on the tranny that connects to the driveshaft via a Porsche CV joint.
Hart_Rod is offline   Reply With Quote
Old 09-27-2014, 06:04 PM   #15
nsb29
nsb29's Avatar
nice exhaust! the adapter looks like its well tested
Old 09-27-2014, 07:56 PM   #16
Hart_Rod
Hart_Rod's Avatar
Thanks. The driveshaft is supposed to be rated for 1000+ HP.
http://www.driveshaftshop.com/domest...ece-driveshaft
Old 09-28-2014, 01:41 AM   #17
DLW
So they pretty much made it custom to the length you needed and added a standard type 1350 on the Diff. end?
Old 09-28-2014, 05:55 AM   #18
Hart_Rod
Hart_Rod's Avatar
That's correct.
Old 09-28-2014, 06:33 AM   #19
jjzepplin
jjzepplin's Avatar
Wholly smokes you fellas have some nice rides! Excuse me - I have to go fertilize my money tree! LOL
That billet unit looks awesome. I am inspired. The search for a doner is on.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-28-2014, 08:55 AM   #20
nsb29
nsb29's Avatar
10-4 on the money tree $$$$$ this motor only makes 360 hp but it will be a daily driver and long trips with the airstream it has to be dependable
Old 10-03-2014, 05:49 PM   #21
nsb29
nsb29's Avatar
thanks every one for all the input doug
Old 10-16-2014, 09:15 AM   #22
nsb29
nsb29's Avatar
Name:  i phon 043.jpg
Size:  36.7 KBI got my 400 yoke back from the machine shop yesterday her are some pictures I found out you cant go to your normal machine shop you have to go to your local jesse james al the big shops wont to hit a home run on every job I hope this helps someone it cost me 45.00 for the yoke 60.00 for the machine work im not cheap I just didn't like using the extra part when using the adapter doug
Old 10-16-2014, 11:29 PM   #23
clinebarger
I'm glad you found a competent machinist.
Reinstall the 3-bolt yolk with the Center Nut.
Cut off the Output Shaft flush with the Nut. A portable Band Saw does the Cleanest/Coolest Cut.
Install TH400 yolk & Nut. Test a U-Joint for a range of motion.
Old 10-30-2014, 04:01 PM   #24
DLW
What size U-joint does that take?
does that act as a slip yoke or is it bolted on the tail shaft like the stock 3 prong is?
Old 10-30-2014, 08:16 PM   #25
nsb29
nsb29's Avatar
its a bolt on yoke, that's why you have to use the 400 bolt on yoke the 6l80e slip yoke is not right because you will half to press the u joint together in the truck the 400 that I used bolts together like the differential end look at the pictures and you will see what we art talking about. P S the slip is in the drive shaft like the 4by4s
