will tubular a-arms sit lower ?
My a-arms sit on the ground now but was wondering if I would sit abit lower with tube a-arms,pic would be nice .I see some like CPP are made a little thinner than some.
Re: will tubular a-arms sit lower ?
yes is bagged
67-72 parts collector,…
![]() Join Date: Nov 2002
No.
The a-arm pivot point is the lowest part of the front suspension. Doesn't matter what brand you have.
With out a dropmember or zing the frame its as low as it can go now.
Are your arms shaved at the mount points? You can get about an inch lower by dragging them on the ground and shaving it all flat.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 1963 Scout Retro-mod https://67-72chevytrucks.com/vboard/...d.php?t=854167 |
so a tubalar a-arm would sit about 1 inch lower?
This is as low as you can get with a stock crossmember and no frame Z.
A-arms won't change anything,...
![]() Join Date: Oct 2012
Just for information purposes, (3) questions. In that pic lolife99, were the inner fenders removed? If I cupped the lower control, willing sit lower? What set up is that in the picture? I'll take that set up if it keeps me from spending $3300.00.
Pancake the front member 1.5"
#11 | |||
Cupped arms can get it lower vs not cupping. A notched x-member can get it lower vs an un-modified x-member. Dropped spindles help get it lower vs stock units. Z-ing the frame can get it lower vs w/stock frame rails. All these suggestions are less than the cost you mentioned but potentially not as safe either depending on the fab work & attention to safety related details.
Thanks for the info SCOTI. I guess in have my work cut out for me. My Air bags are installed using the bagged plates/brackets. I installed the belltech 3 inch drop spindles. I guess my next step will be to cup the lower control arms and remove my inner fenders and see how it sits. Thanks again SCOTI.
No prob. I'm carving up an extra set now. My goal is not max drop though.... I want the bags @ their spec'd height when I'm @ my desired ride height & it wasn't going to happen w/o slicing & dicing.
And here is what I tried to explain earlier. The crossmember sits off the ground,
Some content in this post has been removed by the moderator as it advocates an unsafe practice.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 1963 Scout Retro-mod https://67-72chevytrucks.com/vboard/...d.php?t=854167 Last edited by panhandler62; 09-02-2014 at 09:22 AM. |
#15 |
![]() Join Date: Jan 2011
That is a big time safety issue grinding the arms flat.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#16 | |
You can't be serious.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by panhandler62; 09-02-2014 at 09:23 AM. |
#17 |
I have drop spindles, and cupped stock arms and my a arms sit hard. I've had a few accidental scrapes from riding low and the connection point of the a arm hitting the ground. Now my A arm is bent right there
#18 |
Thanks Ironadict. For the front bag install, I used the c10 bag plates. I'm not looking for maximum depth, I want the air bag to sit in the modified control arm evenly. Those plates suck. Every so often I have to adjust so that bags sit evenly for even air pressure. If one of that bags are positioned awkwardly on the spring pocket, it throws the bag pressures out of whack and the shor'Dee sits uneven.
