Old 09-18-2014, 03:48 PM   #1
Rich84
Rich84's Avatar
700r4 No Lockup
I'm having an issue with my 700 not going into lockup.
It will lockup in 4th gear before the tranny gets fully warmed up. Once it gets good and warm, no more lockup.
Any ideas where I should start?
Rich84 is offline   Reply With Quote
Old 09-18-2014, 08:43 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: 700r4 No Lockup
Lockup is electrically controlled.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-18-2014, 09:05 PM   #3
Rascal_one2001
Rascal_one2001's Avatar
Re: 700r4 No Lockup
I would drop the pan and replace the harness and temp switch to make sure everything is hooked up right. Trans should not have lock up until it is up to temp.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 09-18-2014, 09:05 PM   #4
geezer#99
geezer#99's Avatar
Re: 700r4 No Lockup
[QUOTE=Just call me Sean;6848305]Lockup is electrically controlled.
By a switch that is controlled by vacuum from the carb via the thermal vacuum switch on the front of the intake.
Maybe the vac lines are on the wrong ports of the tvs.
geezer#99 is online now   Reply With Quote
Old 09-18-2014, 09:30 PM   #5
Just call me Sean
Re: 700r4 No Lockup
[quote=geezer#99;6848338]
Depends. He didn't give a year.
Old 09-18-2014, 10:58 PM   #6
beamn7
Re: 700r4 No Lockup
Exactly. Some of these had a temp switch that interrupts the ground signal to the TCC solenoid. Possible bad temp switch or a pressure switch or the TCC solenoid itself has gone bad and has a poor winding that is loosing connection once it is at operating temp.
Wiring configuration, number of pressure switches, temp switch, and if unit has vaccum control lockup or not all depends on year and model....
beamn7 is offline   Reply With Quote
Old 09-19-2014, 07:24 AM   #7
Rich84
Rich84's Avatar
Re: 700r4 No Lockup
I guess I left out some important information.
My truck has a 1985 z28 TPI engine and transmission. I know that the ECM controls lockup when certain parameters are met (speed,Temp Etc..).
