Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 09-14-2014, 07:21 PM   #826
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: GM Semis
Like the Conventional Cab one. Don't remember ever seeing one like it, but it's pretty cool.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 09-14-2014, 11:04 PM   #827
junkmandan3
junkmandan3's Avatar
Re: GM Semis
Crown Steel used to make the cabs for Mack and White Motor Co. 50 miles down the road.
Allison released automatic transmissions for trucks in 1957, but prior to that had planetary power shift transmissions that were used off highway. The early MT 40,41,42 had front and rear pumps so could be push started.They normally started in 3rd gear...................unless the driver selected the 1-2 position. The HT 70 was similar, but bigger and could be behind 8V71, 350 Cummins, but Allison always had an input torque limit .
GMC used the Hydramatic car 4 speed in medium trucks in 54, possibly '53 .
junkmandan3 is offline   Reply With Quote
Old 09-18-2014, 08:00 AM   #828
pacarhauler
Re: GM Semis
I think the Hydramatic first appeared in these M135/M211 GMCs built for the military starting in 1951. When I was in the army (1966/67) most were used for driver training or Nat'l Guard. XM211, 1952 (GMC) by PAcarhauler, on Flickr
pacarhauler is offline   Reply With Quote
Old 09-18-2014, 09:33 AM   #829
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
Facebook
Old 09-18-2014, 09:50 AM   #830
68panelman
68panelman's Avatar
Re: GM Semis
That's ^ nice!!!
68panelman is offline   Reply With Quote
Old 09-19-2014, 11:47 AM   #831
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
Shared with Permission
Old 09-19-2014, 03:31 PM   #832
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
[QUOTE=KQQL IT;6840708]
Maybe a repost
Still alive and part timing.[
/QUOTE]
Old 09-19-2014, 04:37 PM   #833
C10 - C90 Bill
Re: GM Semis
Sure is load of gold there, including the truck hauling it.
GMC 9500 Fan
Detroit Diesel Fan
Old 09-19-2014, 09:12 PM   #834
68panelman
68panelman's Avatar
Re: GM Semis
Good stuff indeed!, I like the red Autocar, Wondering what's powering the early Autocar with the later chassis/rears, Cool trucks.
Old 09-23-2014, 09:54 PM   #835
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
Old 09-23-2014, 11:44 PM   #836
C10 - C90 Bill
Re: GM Semis
Great picture.
The truck looks fairly new.
GMC 9500 Fan
Detroit Diesel Fan
Old 09-24-2014, 12:13 AM   #837
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
Do the C40 and up follow the pickup cabs. Look like that is a 64-66 cab?
Or where behind a bit
Old 09-24-2014, 12:17 AM   #838
C10 - C90 Bill
Re: GM Semis
Right, that is basically the same as a Pick-Up Cab. Many of the parts will interchange.
GMC 9500 Fan
Detroit Diesel Fan
Old 09-24-2014, 01:12 AM   #839
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
I thought that was the case. Just was curious if the years followed the pickups.
60-63 64-66 and so on.
Old 09-24-2014, 08:38 AM   #840
C10 - C90 Bill
Re: GM Semis
Right, they followed the same style Cab in year models. Same with '67 to '72, a C-70 Medium has basically the same Cab as a C-10.
GMC 9500 Fan
Detroit Diesel Fan
Old 09-30-2014, 01:22 PM   #841
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
Mike Kelett via facebook
Old 10-04-2014, 06:59 AM   #842
GM72K10
Next!
GM72K10's Avatar
Re: GM Semis
GMC 860s, 1959s?
Hope this isn't a repost
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 10-10-2014, 12:42 PM   #843
junkmandan3
Re: GM Semis
I had the hots for 860s so bad about 25 years ago, then my lust switched to the early '50s fat cabs. So I bought two 503 gas powered and one with 4-71 GM diesel. Now I have none .
Old 10-10-2014, 02:42 PM   #844
C10 - C90 Bill
Re: GM Semis
You still have an MH or two, I believe ??
GMC 9500 Fan
Detroit Diesel Fan
Old 10-11-2014, 02:38 AM   #845
Bob B.
Re: GM Semis
The DR-860 was actually built through 1962. Reason I was told was because the 860 had the 6-71 inline Detroit, and the DB-7000 which was supposed to replace the 860 had the 6V-71 V-6. The 6V-71 had cooling problems early on and a lot of fleets still wanted the 6-71, so the 860 stayed around until the DBI-7000 came out which had the 6-71. Junkmandan, does that sound right to you?
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 10-11-2014, 06:49 AM   #846
GM72K10
Next!
GM72K10's Avatar
Re: GM Semis
4x4 conversion towing a Greyhound Bus
86 K30 CUCV M1028A1
Old 10-11-2014, 07:53 AM   #847
watahyahknow
watahyahknow's Avatar
Re: GM Semis
allmost looks like the used the undercariage of a militairy truck for that one
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-12-2014, 01:36 PM   #848
junkmandan3
Re: GM Semis
All the initial V-71 blocks were built with no cooling below the port, and if you were taking the max horsepower out of 'em, they'd seize the pistons. Then, after removing the liners for overhaul, you'd find the block lower half shifted in relation to the top portion. So a bore job was required and oversize liners installed. Then you might get 35,000 miles and have to do it again . I believe around 62-63 DD came out with water below port blocks, then the Vs lived . Another part of the equation was the 200 lb weight saving the 6V71 offered over the inline .
Old 10-12-2014, 01:52 PM   #849
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: GM Semis
702 v12
GMC: http://youtu.be/KnQElM3Qr6Y
Old 10-12-2014, 02:26 PM   #850
junkmandan3
Re: GM Semis
What-----------When you see the big hubs on front wheels, it's usually a product of Marmon-Harrington from Colorado or Howe-Coleman out of upstate New York.
