Old 09-18-2014, 09:09 AM   #26
Crash_OK
Crash_OK's Avatar
Re: LS SWAP 4l60e problems
Originally Posted by clinebarger View Post
If it's shifting good, Don't lose any sleep over it. The ATF took a hit more than the Trans.
What ATF are you running?
Thanks... That is my plan, it seems to be working great...
I am using Valvoline Dexron III... Should I think about using something else?
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 09-18-2014, 09:54 AM   #27
boostedc10
boostedc10's Avatar
Good to hear you got it straightened out. Good info on the issue too.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-18-2014, 07:03 PM   #28
clinebarger
You may consider doing a couple Drain & Fills to replenish the additives that may have depleted from the high heat.
Valvoline Dex/Merc is a good conventional ATF. I didn't want to recommend draining a expensive Group IV synthetic ATF if that's what you were running.
clinebarger is offline   Reply With Quote
Old 09-18-2014, 07:39 PM   #29
boostedc10
boostedc10's Avatar
Lol Cline I was waiting on his answer too before recommending a drain and fill. You pockets empty fast with a synthetic!
Brandon
Instagram: DRVFSTR
Old 09-18-2014, 09:15 PM   #30
83 Silverado
83 Silverado's Avatar
I'm curious to your thoughts on getting a machine flush done after all that?
I know a lot of shop have a trans flush machine now a days, and it can clean out the trans, converter and trans cooler all in one shot, plus it likely be a half hour to hour labour at most shops.
83 Silverado is offline   Reply With Quote
Old 09-19-2014, 08:25 PM   #31
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The only thing I've ever seen a flush do is push out the remaining good seals, find every leak you have, and ensure that you'll get upsold by the tranny shop. They fall into the category of convenience services I don't trust, performed by people who shouldn't be near my truck.
If everything was brand new, and there was a reason to think something physically was clogged, then I might say yes. But on a trans with more than a couple miles on it I stay away.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-19-2014, 09:16 PM   #32
Hart_Rod
Hart_Rod's Avatar
+1
Hart_Rod is offline   Reply With Quote
Old 09-20-2014, 07:29 PM   #33
clinebarger
I don't use or recommend their use, They pose a great risk for contamination, And as Brew said....Are often operated by unskilled personal.
