Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 09-08-2014, 12:01 PM   #1
Grumpy old man
Grumpy old man's Avatar
New low cost chain covers installs in less than 5 minutes !
I have a new design set of chain covers made from UV treated automotive grade VINYL -stitched using UV treated NYMO thread the best you can buy These are 18 inches long (measure your chains for correct length ) these are double sewn and have a drain hole so no need to remove water after washing or rain ! Since they are flexible simply slide them over your chain hook end they have a cable tie sewn into them to prevent the cover from sliding down --tighten cable tie snugly and trim repeat on hook side and your done! No need to remove chains to install ! many colors PM for other colors and length you need them . No more scratched paint! -- No more rattling chains !
$25.00 a set SHIPPED !
http://http://http://http://http://
Old 09-21-2014, 12:37 AM   #2
tmoble
Re: New low cost chain covers installs in less than 5 minutes !
no replies? these covers still available?
tmoble is offline   Reply With Quote
Old 09-21-2014, 08:52 AM   #3
Grumpy old man
I've sold a few thru Pm , They will always be available .
