Old 09-19-2014, 02:38 PM   #176
Coursey
Coursey's Avatar
Re: 1971 Chevy C10 SWB - Elizabethtown, Ky
I may have missed this somewhere.
What is the total drop on the truck front and rear?
Who's products did you use?
Coursey is offline   Reply With Quote
Old 09-20-2014, 11:10 PM   #177
knomadd
knomadd's Avatar
Exhaust turned out great!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-21-2014, 08:02 AM   #178
Bennett68C10
Bennett68C10's Avatar
Originally Posted by mcbassin View Post
Exhaust turned out great! your truck looks awesome too!
X2
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-21-2014, 08:33 PM   #179
soundqdoug
soundqdoug's Avatar
Way cool truck. Tuxedo version!
soundqdoug is offline   Reply With Quote
Old 09-22-2014, 04:16 PM   #180
csfields
csfields's Avatar
The front is dropped 3.5 inches (2.5 inch drop spindles and 1 inch shorter spring). The rear is dropped 6 inches ( 2 inch blocks and 4 inch shorter springs).
All on 20" wheels.
I used CPP blocks, drop spindles & got the shorter springs from Southern Kentucky Classics.
With this drop I had to get a bent pan hard bar, also from CPP as the stock straight one hit the rear end cover. I also used a CPP C-notch kit.
Hope this helps.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 09-22-2014, 04:19 PM   #181
csfields
csfields's Avatar
I just noticed you are from Kentucky also, what part?
Thanks,
Casey
Old 09-22-2014, 04:38 PM   #182
Coursey
Coursey's Avatar
Benton near Paducah
Old 09-29-2014, 01:36 PM   #183
csfields
csfields's Avatar
Wrapping it up Got the headlight bezels in, washer jug, wipers, etc. Hopefully it's completed for awhile. Got it on the road and drove great. Even made my first show this past Sunday and took home best truck. I will keep this updated as I already have things I am wanting to add and modify, as we all know a truck is never truly finished.
I also ordered a shirt from the website and had it modified with my name and truck year on the back. SUPPORT THE WEBSITE. Couldn't have done all this without the help of everyones vasty knowledge.
Thanks,
Casey
Old 09-29-2014, 01:39 PM   #184
csfields
csfields's Avatar
Here are some pics from the first car show. Like I mentioned above took home Best Truck and my Dad took home Best of Show with his 55 Chevy Gasser. It was a good show. Typically it's just me and Dad, but my daughter and Fiance wanted to go for the first show as well.
Thanks,
Casey
Old 09-29-2014, 02:33 PM   #185
Xeen
Xeen's Avatar
The pickup really looks great.
Congratulations on your win.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-29-2016, 10:47 PM   #186
SKT
SKT's Avatar
Awesome work w/ this frame-off build!
Truck turned out looking amazing!
SKT is offline   Reply With Quote
Old 07-03-2017, 08:09 PM   #187
Lowell_70C10
I started with a search for gas tank relocation...... Saw your tank and had to see the entire rebuild. It was a great hour spent seeing your hard work and resources spent! ;-) Great Job!
Lowell_70C10 is offline   Reply With Quote
Old 07-04-2017, 10:53 PM   #188
csfields
csfields's Avatar
Thanks. It's always nice to help some one and get a compliment the same time. Good luck.
Old 07-05-2017, 12:42 AM   #189
Jason7121
Jason7121's Avatar
Great work on the truck love the detailRd work. If you dont mind me asking you a question. On your fuel tank do you run a rollover valve and a vent seperate? And if so where does your vent go? Thanks
Jason7121 is offline   Reply With Quote
Old 07-05-2017, 08:14 AM   #190
csfields
csfields's Avatar
Rollover / Vent in same. The vent came off the back right hand corner top of the tank. Ran hose off side of frame rail and up into inner bed side which would be close to right rear marker lamp.
Thanks,
Casey
Old 07-05-2017, 09:53 AM   #191
Jason7121
Jason7121's Avatar
Thanks appreciate the help
