09-20-2014, 10:25 PM | #1 |
What engine part is this?
I'm swapping the inlet manifold on the 283 in our 56 pickup.
I removed the manifold and found this part in the valley (see circled part) Can anyone tell me what it is?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
09-20-2014, 11:08 PM | #2 |
Re: What engine part is this?
It's the breather assembly for crankcase ventilation. basically an oil separator. 283's didn't have PCV stuff in the valve covers. Don't take it out.
09-20-2014, 11:27 PM | #3 |
Just to add a note, also the 327's had the same set-up, Like tmoble said, leave it were its at...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-21-2014, 12:09 AM | #4 |
well, I sent back to your pics to see which type of breather setup was on there, but the pics show that there's Welch plug driven into the hole next to the distributor where the passage comes out. You'll need to have a breather and PCV in the valve covers. The can in the valley doesn't matter if that hole is plugged.
Couple other things, engine looks pretty fresh. I see the Fel-Pro intake gasket and laser etching of the part number on a pushrod. Also see that whoever built it used the problematic rubber end seals on the manifold. Don't put those back, clean the top of the block and bottom end rails of the manifold with spray brake clean and use a bead of RTV across there. It'll never leak or pooch out like the rubber ones. Those things have been the source of a million headaches, throw them away. GM never used them after RTV was invented and available. ugh, whatta PITA those things are. look at end seals to see how thick they are as they as they sail into the trash, your bead of RTV needs to be thicker than that. Let the RTV sit about 10 minutes before setting the manifold on. Lots of guys use a bead about the size of a pencil, that's too big unless there's something weird about your engine. |
09-21-2014, 12:22 AM | #5 |
I dug up a photo of the stock type set-up. At the back of your block a plug has been installed, just passed your oil line. You can either remove the plug and use stock set-up, or if using new valve covers you can install a PCV valve in the covers. Hope this helps...Jim
09-21-2014, 07:53 AM | #6 | |
09-21-2014, 07:53 AM | #7 |
09-21-2014, 07:53 AM | #8 |
Thanks x 2
09-21-2014, 07:56 AM | #9 | |
I have only ever used RTV on the china wall
09-21-2014, 07:57 AM | #10 | |
09-21-2014, 10:30 AM | #11 |
Not sure, just a pic I got off the net...Jim
09-21-2014, 12:53 PM | #12 |
technically that is the oil baffle for the road draft tube
pre-pcv valve means of getting the blow-by out of the engine bay and directly into the atmosphere or dripping on the road
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-21-2014, 08:44 PM | #13 |
that's why it's usually called a read drip tube.
