08-15-2014, 07:45 PM | #401 |
Re: Pre Mothers Day sale 67-72 truck parts
post #19 pic #2 i see you have burb upper support brackets will they work on a 66 burb? if so i need both right and left if not i need em anyway!!!
08-15-2014, 10:55 PM | #402 |
How much for these shipped to 27892? Thanks.
1) dash speaker bracket 1) clutch block off cover 1) cig lighter harness 1) dual horn harness 1) heater hoses bracket (mounts to battery box) 1) Headlight knob/shaft (w/silver insert) 1) Wiper switch knob (w/silver insert) |
08-15-2014, 11:01 PM | #403 |
Just like to part out trucks!!
Winston, sorry none right now
chubinit, I have all that stuff but not sure what your wanting on heater hose bracket? $35 shipped for all Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
08-26-2014, 07:06 PM | #404 |
im looking for a HO52 3/4 ton floating hub, 8 lug.. drivers side rear..
08-26-2014, 08:24 PM | #405 |
Sorry none right now, Thanks
08-26-2014, 08:33 PM | #406 |
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
You wouldn't happen to have a clean, used auto gear lever for a "70 model would you?
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
08-26-2014, 08:56 PM | #407 |
09-03-2014, 02:50 PM | #408 |
hey randy, would you happen to have a 69-72 4x4 left, drivers side, front spring, front mount? the very front one with the radiator support mount. thanks, jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
09-03-2014, 03:21 PM | #409 |
Hi, Do you have 67/68 Fleetside tail light bezels. If so I'd like to add a battery hold down as well. Please let me know how much it'll be.
Thanks!
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman |
09-03-2014, 05:46 PM | #410 |
Jake, sorry none right now
Mike, no bezels but I have bat holddowns Thanks Randy
09-19-2014, 01:59 PM | #411 |
Thanks Randy,
I'm interested in: 1. GMC Turn signal pigtails- don't necessarily need the housings 2. Post 10, pic #2- are those GM emblems Choke Delete? if so I'll take one 3. Battery hold down with screw if you have it 4. Post 15, Pic #2 tail light bezels? Please let me know the total with shipping to 48326. Thanks!
09-21-2014, 09:24 PM | #412 |
Let me check on the pigtails I'm not sure they are still out there. The GM emblems are for 67 doors. I have battery holddowns. The only taillight bezels I have dents in them, thanks Randy
09-22-2014, 09:24 AM | #413 | |
Thanks for the reply, Don't worry about the pig tails, I think I have found a solution locally. If you don't mind posting a pic of the tail light bezels, as long as they aren't too bad I'll take them, my truck is a driver. I will take a battery hold down and bolt. Thanks again.
04-23-2023, 12:58 PM | #414 |
Interested in the T3 headlight if it is the single large hi/lo beam bulb and it is functional. Also, just experienced a fire on a project truck ('69 shortbox 4WD), did minor damage. Am looking for the wire harness that runs across the top of the radiator support and the wiring trough (holds the wiring harness). You wouldn't have any cab light lenses?
-Thaddeus in Bozeman, Mt |
04-23-2023, 01:45 PM | #415 |
Nine year old thread from teeitup, he recently got back active to the board again but not sure what parts he has.
Just a friendly suggestion, if doing a forum search for parts, always check the posting date before responding to a thread.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
08-18-2023, 05:21 PM | #416 |
Do you have a 1972 brake pedal bracket? Auto, no clutch pedal. Thanks
My 1970 C10 ChassisFab LWB to SWB Build Thread |
