![]() Join Date: Aug 2004
Re: Will these motor mounts work?
When I did my swap, the CPP perches were the only ones available. I got the stock perches to work, but man that was a real PITA!
I finally went with the POL perches, this sits the motor up a little bit more, making headers fit easier and maintenance much easier. Oh, BTW be sure to swap your oil pan out prior to setting the motor in, I learned the hard way. Good Luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
