Old 09-19-2014, 06:58 PM   #1
K10Dream69
K10Dream69's Avatar
Help finding Engine Stamp #'s on 71 BB
Hello, Sorry if this answer posted already somewhere.
I've been searching and I can't seem to find a definitive answer.
My truck has a 454 in it but I'm not sure out of what.
I've seen a few posts that the code is posted under the driver side valve cover.
I've seen others that say it's on the rear drivers side of the block, another that says front passenger side head.
Any input is appreciated. Thank you
K10Dream69 is offline   Reply With Quote
Old 09-19-2014, 08:11 PM   #2
vidman
vidman's Avatar
Re: Help finding Engine Stamp #'s on 71 BB
casting numbers are on top of block behind the drivers head. suffix codes are stamped on top of the block in front of pass head..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 09-23-2014, 03:39 PM   #3
K10Dream69
K10Dream69's Avatar
So there's virtually no way of seeing this code?
My BB is maybe an 1" off the firewall. I wish there was an easier way to see it.
Thanks for the help
Old 09-23-2014, 03:54 PM   #4
john
member #16
john's Avatar
Try this.
http://www.nastyz28.com/decode.php
john is offline   Reply With Quote
Old 09-23-2014, 03:54 PM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
You can hold a digital camera pointed down back there and snap away. Also mirrors are good for this too.
If your engine has a stock intake get the casting #'s off of it. There are casting #'s on the heads but you have to pull the valve covers. All these numbers add up and should give you something to go on.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 09-23-2014, 06:34 PM   #6
K10Dream69
K10Dream69's Avatar
So I just pulled the valve covers off quick n this is what I came up with.
Driver Side #'s B2678 GM10T
Passenger Side #'s 358049 GM10T
I tried with a mirror and flashlight and I couldn't get anything off the back off the driver head.
Old 09-23-2014, 07:09 PM   #7
john
member #16
john's Avatar
The casting number on the rear of the block will tell you it is a 454. The suffix codes on the right front will tell you the application it was used in. Sometimes they do disappear if the block has been resurfaced.
