Self-proclaimed LED man
Has anyone ever put subwoofers under their seats? If so how big is the biggest box that will fit under the seat?? Thanks
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
i wanted to do it but there isnt enough heighth under there. at least not in the buckets in my blazer. i was trying for an 8 or 10.
69k5 |
Formerly yellow72custom
I measured under the seat of my truck, and found 5.5" of vertical room (i THINK...it was a while ago). Some 10" subs have a top-mount depth of 4.5" so it should be easily done with some custom boxes. I don't think you would be able to fit anything bigger than a pair of 10's under there, unless you find some really short 12's. But, 2 10's would be plenty for the small cab size of these trucks
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Try spinnin 4 rear tars
I have an 8" under the center of my bench. Just barely fits. I certain you could fit a 10" under there if you put it on either side of the seat so that it isn't on that tiny hump.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
I have two 8 inch roadgear subs with a 400watt amp. The boxes ive built are probably too small for the sub, but 5 inches is the bigest that is going to fit under the seat. Thanks for the help. Im installing thses under a bench seat and mounting the amp ontop of the hump under the seat. its a mofset amp so hopefully it wont get too hot under there.
SWB 4x4 Collector
![]() Join Date: Jun 2001
I fit 2 kicker 10'' subs under my factory buckets and put the amp behind the passenger seat. had to fab my own slightly angled boxes .. .but it worked
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Never thought of angleing them. Maybe ill try that.
I had some old school kickers back in the day In a 72 air cab I had to make the smallest boxes that was before i knew anything about air space they sounded ok not the greatest but there 8s
the air space thing is gonna be a tuff cookie go with a sealed box requires less air space as i recall but every speaker uses a different air space. |
ya im going to seal the boxes up with liquid nails. Right now the boxes are 12x12x+-5inches.
I made my own sealed boxes a couple years ago. I used an 8 under each seat and the amp behind the passengers seat. Looked nice and clean, but you need to get the airspace right. Otherwise don't waste your time. Talk to a car audio guy and he should know how big to make them. Also box shape is can to be important (don't know if its true but thats what I was told). My mistake was building them and THEN going to find out "why don't they hit harder?". Good luck.
Don't say "Oops!", Doctor
Here's a list of links that go into detail about enclosure design and theory. Maybe it'll help somebody here.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
Dreams are free
A buddy of mine cut out a section of floor, under each side off the hump, and built a new box if you will ,out off metal to allow for more room, a sunken in box , If you can understand what i'm trying to say, you couldn't see it from the outside, and it sounded good.
'68 swb fleetside originally w.i.p '68 member since 1-01 w.i.p = ( work in progress ) |
Theres no way im gonna cut the floor. I just had speed-liner sprayed on the floors. Im afraid the sub wont sound very good since i dont have much cubic feet. Right now i have .23 something per sub.
December 21, 2012
I couldnt fit them under my seat so I made some custom boxes to the same dimenision of where the fuel tank was and put them behind my seat. I put the changer and amps under the driver and passenger seats respectively.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
#15 |
The solution in my truck was a free air speaker. It is a kicker free air 10 mounted in a "box" just the box has not back and sits on the carpet. Sounds great. Combined with the separates in the door and the CD changer it is the least intrusive, best sounding package I have seen.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 01-13-2004 at 12:59 AM. |
#16 |
ttt
