Old 09-25-2014, 03:30 AM   #3
Johhny
Re: NP203 input shaft swap?
You were correct, they do interchange. I ran into a new problem tho:
I disassembled the old np203:
took out the input drive gear (32 spline):
and placed it in the new tcase:
Everything fits perfectly but I can't seem to reassemble the range box case...
There's a lever with shaft combined with a lockout shift that's located in the range box case itself:
The lever with shaft goes on 1, the lockout shift goes on 2:
I have no idea how to connected this when putting the case on, it al has to connect when the case is already half on, anyone has any suggestions?
Johhny is offline   Reply With Quote
mile marker, np203, suburban, swap, th400
