Old 09-25-2014, 12:31 AM   #1
allways
Unhappy motor runs bad please help
hi, I pulled a sb 427 with aluminum heads out of my 1955 chev 210 and put it into my 1972 c10 I put in new spark plugs changed distributor and replaced carb base plate gaskets this is a new crate motor with zero miles on it ran like a dream in the 1955 but runs like crap in pickup cant figure out why. other than the things listed above I did put anti seize on the plugs do you think this could be my problem?
allways is offline   Reply With Quote
Old 09-25-2014, 01:16 AM   #2
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: motor runs bad please help
Hello allways and welcome to the board. I moved your thread to the Engine and Drivetrain area so some of our engine experts on the board can give you a hand.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 09-25-2014, 08:31 AM   #3
Rollo McFlurry
The obvious answer to me is put the old distributor back in and try it. Sometimes a new distributor can have faulty parts. i.e. module, sticky weights, bad pickup.
Rollo McFlurry is offline   Reply With Quote
Old 09-25-2014, 09:12 AM   #4
imjeff
imjeff's Avatar
I would agree with Rollo. It's almost always what you "fixed". If it ran great before the swap, why did you put the new distributor and gaskets in? A little more history and pics will help. It's a SB 427?
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 09-25-2014, 09:15 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Just as an fyi; Bad gas can cause the symptoms you describe and can lead you astray in trying to analyze the problem.
Other possibilities; Using the old resistive wiring on an HEI distributer. It needs full 12vdc.
Sparkplug cabling crossed.
Vacuum leaks. I unplug all the vacuum lines -power brake booster, automatic transmission- and plug them up as a test.
If all the above are okay and you're not sure about the fuel in the tank: Buy a 1 gallon can of fresh gas. Place it under the truck under fuel pump. Remove the inlet rubber hose to the fuel pump and replace with app. a 2 ft. fuel hose going into the one gallon container.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-25-2014, 09:41 AM   #6
AcampoDave
AcampoDave's Avatar
Distributor 180 out?
AcampoDave is offline   Reply With Quote
Old 09-25-2014, 10:56 AM   #7
DBD
Job one is to check the timing - simple and quick. There may be a lot of things going on, but this is the first thing.
DBD is offline   Reply With Quote
Old 09-25-2014, 11:26 AM   #8
storm9c1
*** That's interesting ***
storm9c1's Avatar
I agree with everyone so far. The distributor is what changed between the two swaps, so I would check that first. This includes timing and firing order of the plug wires! Is the new distributor HEI or points? Geezer may be on to something with the wiring depending on what distributor the truck USED to have and which one is on there NOW. If new one is HEI, try running a temporary power wire straight to the distributor from the battery and see if it runs better.
Did you retain the old carb? You mentioned you changed the gaskets? Sure those are sealing?
How long ago did this engine run properly?
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 09-25-2014, 11:50 AM   #9
cg285
well, according to the first post it's a new crate motor with zero miles.
cg285 is offline   Reply With Quote
Old 09-25-2014, 11:58 AM   #10
imjeff
imjeff's Avatar
The lines "I pulled a sb 427 with aluminum heads out of my 1955 chev 210" and "it ran like a dream in the 1955" from the first post seem to indicate it's not a zero mile motor.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 09-25-2014, 12:01 PM   #11
cg285
correct. he also said "this is a new crate motor with zero miles on it"
just reading what is written
Old 09-25-2014, 12:24 PM   #12
ERASER5
ERASER5's Avatar
So the crate motor was in the 55 but it never go out of the garage. But the engine did run. Now it does not, or at least correctly.
I say dizzy, and firing order are at the top of the list.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-25-2014, 12:26 PM   #13
dfrank
dfrank's Avatar
Check distributor and spark plug wiring and also timing.
dfrank is offline   Reply With Quote
Old 09-25-2014, 12:40 PM   #14
cg285
and i say it can't be diagnosed, only guessed at, without more correct information. "runs like crap" somehow just doesn't get it.
Old 09-25-2014, 12:44 PM   #15
marvgarr68
marvgarr68's Avatar
Check the carb gasket. I have had trouble with them before sometimes they are not cut right. Also check the timing.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 09-25-2014, 01:03 PM   #16
imjeff
imjeff's Avatar
I missed how long ago it "ran like a dream.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 09-25-2014, 03:18 PM   #17
storm9c1
storm9c1's Avatar
Me too. And if it never left the garage, I question what "running like a dream" sounds like. So does that mean it started up and idled like a dream once? OK, when was that? I hope it's not a flat tappet cam engine that wasn't broke-in properly...
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 09-25-2014, 04:03 PM   #18
imjeff
imjeff's Avatar
Good point! There are a lot of good places to look. Hopefully the OP will fill in some blanks.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 10-06-2014, 01:13 PM   #19
allways
sorry been a while hurt my back
think I found problem check ball in carb for power valve stuck when trying to start popped back will see when back is better. Motor was pro built and dyno
Old 10-06-2014, 01:27 PM   #20
allways
more info on motor sbc 427 shp block howards roller cam dart pro 1 heads quick fuel mech 750 no acc zero miles broke in by shop and dyno 554 hp 588 torque. pulled dist to put in stock dist not that.started reading on line and found that some time that little ck ball will stick if popes back it was stuck.
Old 10-06-2014, 01:32 PM   #21
imjeff
imjeff's Avatar
Sbc 427?
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 10-06-2014, 01:38 PM   #22
allways
yes small block 427 ci 4" stroke 6" rods
