191 tilt column
I got this rebuilt column with my 1971, can anyone tell me if it is a 68-72 column or exactly what year? Thanks.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 191 tilt column
Looks like a true truck tilt column to me and correct for 69-72 I believe
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: 191 tilt column
I agree
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
![]() Join Date: Apr 2010
Re: 191 tilt column
No, it is a van column with the correct length shaft for a truck!
Carpe manana
Re: 191 tilt column
Oh, is it the position of the neutral safety switch higher up on the column?
Re: 191 tilt column
I hate to disagree with 70 short fleet cause I know he knows his stuff and I may be wrong but it looks kinda like a motor home column to me. but then again it has been a while since I've got to look at any of my stuff much less work on it. Please forgive me if I am wrong. Jim
Re: 191 tilt column
The angle of the shifter arm is what makes me trigger that memory.
Re: 191 tilt column
Jim, I do forgive you
Re: 191 tilt column
I can be wrong all day as long as you do as good as a job on the next cluster as you did on the last one I got from you. Even though I put it in and a tilt at the same time I have only driven it like 9 miles since then. That is shameful I know. Time slips away from me so easy now I think I'll do it a little later and a couple of years pass. I am getting things in and out of the shop, just not my trucks.
