Old 01-18-2004, 09:07 PM   #1
68 Suburban
68 Suburban's Avatar
Rear End Cover Gasket Installation?
What is the best way to instill the gasket for the cover on the rear end? Is that little paper gasket the best thing to use? Thanks
68 Suburban is offline   Reply With Quote
Old 01-18-2004, 09:09 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Yep the paper diff gasket is the way to go. I think if I remember correctly when I did mine that I put on a little bit of silicone too as well just to hold the gasket in place when i went to bolt it on
WRMZ71 is offline   Reply With Quote
Old 01-18-2004, 09:10 PM   #3
zenish
most people just use silicon,no gasket.
zenish is offline   Reply With Quote
Old 01-18-2004, 09:11 PM   #4
68 Suburban
I think that is what is on there now, and has a minor leak ever since I have owned the truck
Old 01-18-2004, 09:11 PM   #5
68 Suburban
Old 01-18-2004, 09:12 PM   #6
rage'nrat638
rage'nrat638's Avatar
gasket and silicone
rage'nrat638 is offline   Reply With Quote
Old 01-19-2004, 01:05 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
We use 3 M Super 77 Multipurpose Adhesive spray at the shop. Spray on one side of the gasket, let it tack up, and place it on the diff cover. (or water pump or valve cover...what ever we're workin on) Then just bolt it on.
However, for a diff, we just use The Right Stuff most of the time.
Old 01-19-2004, 01:15 AM   #8
Sweet72
Sweet72's Avatar
I use a thin coat of 3M weatherstrip adhesive on the gasket and the cover only. Let it tack-up and stick it, then bolt 'er up. Make sure to straighten the sheet metal cover if it's distorted at the bolt holes.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-19-2004, 06:54 AM   #9
68 Suburban
How much gear lube for a standard truck 12 bolt? Thanks
Old 01-19-2004, 08:08 AM   #10
Longhorn Man
I think it was just under 2 bottles, but I am not quite sure.
Old 01-19-2004, 09:08 AM   #11
Blue Beard
Blue Beard's Avatar
One thing I've found when people use the silicone or rtv sealer...........they always seem to miss a spot...............now the leaks........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
