Will 15x10 wheels fit?
I found a set of 15x10 wheels for cheap..does anyone know if they will fit in the front and rear ok? I feel like the rear will be rubbing?
Re: Will 15x10 wheels fit?
Fit rear very well and front would depend on tire selection.
15x10 Front and Rear.. 4.5" backspace
3.5" Front and 5" Rear Drop |
Yes they will:
will i need spacers?
Like mentioned above, it depends on what tire you go with and how much back spacing are on the wheels you want. Running spacers is okay to a point if you need them. If you know what back spacing the wheels are, we can help you better. Also, is your truck 2wd or 4wd?
[QUOTE=low&slow;6861574]Like mentioned above, it depends on what tire you go with and how much back spacing are on the wheels you want. Running spacers is okay to a point if you need them. If you know what back spacing the wheels are, we can help you better. Also, is your truck 2wd or 4wd?[/QUOT
ok i will have to check that. its a 2wd thiugh |
