Old 09-30-2014, 01:56 AM   #11
Grip
Grip's Avatar
Re: Project "Sleezy" 72 Highlander
Originally Posted by asizemore View Post
Bolted everything up and sat her on the ground to check clearances and what not. Drivers side is approx. 1 inch lower than the passenger side..weird Still have a lot of work to do. More brake line work, install brake booster/master cylinder, and tighten up a few things here and there.
Did you investigate why it was sitting high/low on one side? I'd check that the front spring pig-tail is in the lower control arm pocket on both sides. If it isn't, you might be able to use a spring compressor to squeeze the one that is not seated properly and move it without popping a ball joint. I wish you luck! The truck is looking great!
Eric
68 Anniversary Gold C-20 LWB to C-10 SWB build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637492
It's hard to explain puns to kleptomaniacs because they always take things literally.
Grip is offline   Reply With Quote
