Old 09-28-2014, 08:18 PM   #1
xaircav
xaircav's Avatar
Disappointed with performance of vintage air cleaner
I wanted a vintage look for the 283 in my '53 and a few weeks ago I found an early 60's air cleaner at a swap meet. Part throttle response is flat and it doesn't pull as hard at WOT. Runs great with 14" round air cleaner in pic #2. Carb is an Edelbrock 500 CFM on an Edelbrock EPS intake.
xaircav is offline   Reply With Quote
Old 09-28-2014, 08:49 PM   #2
mr48chev
mr48chev's Avatar
Re: Disappointed with performance of vintage air cleaner
that is the reason that guys pulled the stock ones off and put an aftermarket open one on their car in the first place.
That long snorkel with the little 2x2 opening is there so the engine is quieter going down the road and you don't hear the rush of air you hear with the open air cleaner even with a little 283. That keeps non performance drivers happier as they hear less noise inside the car.
With a stock 283 with a 2 barrel I'd think the performance you didn't feel you cwere getting was more due to the lack off noise from air going in the carb with the stock air cleaner rather than seat of the pants performance loss though. In other words it didn't sound as fast as it did with the open air cleaner.
My ongoing truck projects:
Old 09-29-2014, 05:30 AM   #3
Old Crow
Old Crow's Avatar
Remember in the old days when we used to turn the air cleaner cover over to get the same effect? My ol' man musta chewed my butt 50 times for that.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 09-29-2014, 08:56 AM   #4
1project2many
Shape pf filter can is different, air entry into carb is different. OEM can works best with OEM carb. Spacer between can and carb likely will show a difference.
Put water manometer or sensitive vacuum gauge on canister and watch what happens inside can while driving. Any vacuum at all indicates restriction and can drastically changes fueling.
1project2many is offline   Reply With Quote
Old 09-29-2014, 01:48 PM   #5
OrrieG
OrrieG's Avatar
My 64 chevelle came with the stock one, but with the snorkle cut off. another old schoold trick was to cut a second hole in the back side. Off road racers in 64-65 had one that had a plenum thru the firewall into the cowl vent, early cowl induction.
Old crow, my memorie is that on some Qjet applications you needed to turn it upside down to get the vacuum secondaries to open.
Old 09-29-2014, 03:12 PM   #6
Old Crow
Old Crow's Avatar
Yeah, Orrie, you may be right about that, but as a kid all I cared about was the sound.
Then I spent 6 years working on GM motor homes and learned about the hidden spring adjustment for the secondary air flap. The problem we found mostly was the air flap not opening, not the actual secondary blades. Back off on the spring and the flap would open, even with the stock air filter in place.
Old Crow
Old 09-30-2014, 11:51 AM   #7
AZ59apacheguy
That's too bad, because the stock air cleaner looks way better/correct than the newer style.
AZ59apacheguy is offline   Reply With Quote
Old 09-30-2014, 02:23 PM   #8
xaircav
xaircav's Avatar
I agree, that's why I wanted it. I have a taller element for it that gives me about a half inch gap between the base and the lid. I'll see if that gives it the extra air I need. I'm just outside Denver a little higher than a mile high so air is at a premium here.
Old 09-30-2014, 02:39 PM   #9
mr48chev
mr48chev's Avatar
It's funny but in the time period you are trying to emulate with the "look" no self respecting hot rodder would have left that stock air cleaner on an engine he stuck in an early truck.
I'm no fan of that all too new should be under the hood of a mid 70's Camaro one either though.
Old 09-30-2014, 04:29 PM   #10
Old Crow
Old Crow's Avatar
My wife's '54 panel came with a little paper element type filter on the carb. I had a stock oil bath cleaner laying around so I cleaned it up and put it on the truck. Drove it home and back to the shop and put the paper filter back on. Runs much better with the paper filter as opposed to the oil bath.
Old Crow
Old 09-30-2014, 05:08 PM   #11
G&R's57GMC
G&R's57GMC's Avatar
If you want the old look how about a Technostalga 8500 Retro Cad / Olds air cleaner.
You can get one from Speedway Motors for $128.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 09-30-2014, 05:20 PM   #12
xaircav
xaircav's Avatar
Not a bad idea for a Plan "B".
Old 09-30-2014, 05:26 PM   #13
xaircav
xaircav's Avatar
I hear you and I see the irony of it too. The Edelbrock carb manual says their carbs were designed to work best with a 14" X 3" open element air cleaner. I guess I have to pick form or function.
Old 09-30-2014, 05:54 PM   #14
G&R's57GMC
G&R's57GMC's Avatar
The Retro Cad unit has a 14"x4" paper filter in it and is designed for the Edelbrock , Holly , Q-Jet & Demon carbs.
Its all steel and has a relief for an HEI distributor .
Opps my bad it's $ 128.99 from Speedway
Go with plan B
Glen & Jane's Rides
Old 09-30-2014, 08:55 PM   #15
Highsider
Highsider's Avatar
Go with plan B
If that housing would cut a bit of intake noise from creeping into the cab, I might be in!
I could stick my 14 X 4 K-N Filter in it!
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 09-30-2014, 09:56 PM   #16
AZ59apacheguy
Here is what I ended up doing on my 283 with 4bbl Rochester. I used an old oil bath style filter housing, removed the oil bath element and replaced it with a paper element. It has a larger opening then yours. I have had it up to speed and don't see much if any drop off in performance.
Old 09-30-2014, 10:04 PM   #17
AZ59apacheguy
Here is what I used when I had a 2 bbl Rochester on it a couple of months ago. I also replaced the oil bath element with a paper one. The two openings up front bring in a LOT of air.
( never mind the incomplete nature of this pic, I just did not have any pics of the engine complete with this air cleaner )
Old 09-30-2014, 11:23 PM   #18
mgchevyparts
mgchevyparts's Avatar
In the mid to late 60's there weren't a lot of aftermarket parts like there are today. You would have most likely had a chrome Cal Custom air cleaner, about 10" in diameter, with a white filter. An aluminum one (Cal Custom) if you were bucks up or a shiny Corvette or GTO air cleaner, the ones with the louvers around the side. Never would you see that Cad in the 60's that was more of a 50's thing.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 10-01-2014, 07:14 AM   #19
Keith Seymore
Keith Seymore's Avatar
I doubt it, since there is no "tuning" in those snorkels. They are wide open.
The only advantage would be they would project the noise forward, rather than rearward toward the firewall (like some other intakes do).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-01-2014, 10:27 AM   #20
Highsider
Highsider's Avatar
K
I was thinking in comparison to this style, which is what I have, sitting on an Eddlebrock.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 10-01-2014, 10:43 AM   #21
geezer#99
geezer#99's Avatar
You want the snorkle air cleaner look and more air, just break out the hole saw and put some holes on the underside close to the edge all around the base.
Old 10-01-2014, 07:58 PM   #22
tmoble
That snorkle in Post #1 will feed a performance type 350 no problem. I'd guess that there is something else coming in to play if it seems to be restricting a 283.
tmoble is offline   Reply With Quote
Old 10-01-2014, 08:45 PM   #23
_Ogre
_Ogre's Avatar
like the air cleaner not allowing wot?
check your linkage to see if it will go wot
shop air compressor timer
Old 10-04-2014, 06:48 PM   #24
xaircav
xaircav's Avatar
You sir, are correct. I've been running around with a blown electric choke fuse with the choke only 1/3 open. I must have shorted the choke terminal while playing musical air cleaners. Is my face red! Vintage air cleaner runs as well as open element air cleaner. I led you guys on a wild goose chase but we got to see some great pics.
Old 10-04-2014, 07:25 PM   #25
RRC
RRC's Avatar
I'm glad you got it worked out.... I put holes in the back of mine and a friends. He went through the same thing, with the holes he is much happier.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
