12 Bolt ID
I have two 12-bolt rearends, one from a '72 and another that I got just to use the axles and possible the 3.42 gearset. I pulled the codes off of the tubes and was looking around for ID charts or something but couldn't find any! Mainly I noticed that the parts rear seems to have a beefier yoke and I was thinking of using it since I'm rebuilding the rear anyway, but I'd like to know what U-joint it uses.
Can anyone decode these and/or tell me how to do so myself? KDA W197 1 THA W148 2
1968 LWB C20 / AC / Wood Bed |
#2 | |
Re: 12 Bolt ID
The first one is an oddball but the second appears to be a 3.73 ratio open carrier diff assembled at Tonawanda. Are you sure that KDAW1971 is a truck housing? My friend, Chevelle Dave, insists it's a 68 chevelle diff with 2.73 ratio and an open carrier. |
Re: 12 Bolt ID
These are both certainly truck 12 bolts! And one is a 3.08 open spring, the other a 3.42 open leaf -- and I'm not saying that the gears weren't swapped at some point but they are def. stock GM gears, and definitely look as old as the housings. There are some other numbers on the pumpkin, I could get those tonight if it would help?
![]() Join Date: Apr 2012
Re: 12 Bolt ID
I found the one stamped THA as a open 3.08 from a 1971 c10. I don't see any rear end from 67-72 that starts with a K. Are you positive about the first 3 letters?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
Re: 12 Bolt ID
I am sure about the letters, but I am not positive that it is 68-72 -- I bought it on craigslist and it looks quite a bit better than the rear that I have. If I recall it may have been out of a mid-80's truck?
#6 | |
Re: 12 Bolt ID
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 12 Bolt ID
How about pics..can't be from the 80s. They were 10 bolts by then.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
could that rearend be from a '64 or '65? they look almost indentical, try looking up the axles codes for those years......I bought a 1964 12 bolt, the track bar bracket mount was welded to the the axle tube -vs. a stud in the top of the housing.
Hope this helps..... Ben |
#9 | |
Re: 12 Bolt ID
I don't know what year or model they are from, that's what I'm curious about.
This site indicates that the 12 bolt went through 1987, at least on some applications.
I'll post a picture of mine, I removed the track bar mount, ground down the welds, powder coated it, but I'd bet that's the one you have, does it have coil spring perches on the axle tubes?
Ben |
Re: 12 Bolt ID
Here's mine:
hope this helps.... Ben |
Re: 12 Bolt ID
That looks really nice! But no, mine has leaf mounts.
#13 | |
Re: 12 Bolt ID
W = Warren 197 = Julian Date, July 16th 1 = 1st Shift THA = 1971 c10 3:07 open W = Warren 148 = Julian Date, May 28th 2 = 2nd Shift You need a date code for the KDA axle. Can't tell you where on the axle to look, but your looking for a letter followed by 3 numbers. Ex. A123
CHEVY/GMC VIN DECODERS |
#14 | |
Re: 12 Bolt ID
#15 |
Re: 12 Bolt ID
So the gears indicate 1974. Couldn't find any code as mentioned though. Still looking for the yoke application but I'll probably just measure it to figure out the proper u-joint.
#16 |
Re: 12 Bolt ID
#17 |
Re: 12 Bolt ID
I measured the yokes, and while I thought that the yoke from the '74 was a 1350 yoke it looks like it is a 1330 yoke. The '71 yoke is a 1310 yoke, and seems to be in pretty good condition so I'm going to use that. The 1330 would have needed a sleeve and straps anyway so that works out I guess. The 1330 is a lot beefier at the pinion splines though, as you can see in the pictures -- and is a bit taller.
