Old 10-01-2014, 09:02 PM   #1
mechanicalman
Trailing arm U-bolts
Question: Are the trailing arm U-bolts re-usable? I heard it mentioned that after they have been in service a long time, if you loosen or remove then that you need to replace them or risk a failure.
I'm reaching out to anyone who has experience failed or not failed, or if this is rule of thumb.
I replaced my trailing arm bushings about 6 years ago, and loosened/retightened the U-bolts to gain clearance to replace the bushings. I had absolutely no trouble loosening them with my Matco 1/2 inch air impact and tightened them to 100 ft lbs. I do live in Arizona, and the bolts were not very rusty and I did spray them just before I did it.
Did I blunder and put myself at risk? Should I get new U-bolts and install them? Never thought I might get myself in trouble so maybe I need to learn. I'm looking for whatever answers are out there, even if they are conflicting then I'll decide on what to do.
mechanicalman is offline   Reply With Quote
Old 10-01-2014, 09:06 PM   #2
trac209
Re: Trailing arm U-bolts
I've reused them with no issues. IF they aren't rusted bad you should be fine
trac209 is offline   Reply With Quote
Old 10-01-2014, 10:20 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I reuse them if there is no visible rust damage to them where they go through the trailing arms. Never had a problem.
LockDoc
Leon
Old 10-01-2014, 11:17 PM   #4
Ricks1971
Ricks1971's Avatar
Rule of thumb. Always replace used u bolts. I guess being a diesel mechanic we always replace u bolts as retorking them stretches them and they could bust. So the added cost is not that much for the safety.
Ricks1971 is offline   Reply With Quote
Old 10-02-2014, 01:58 AM   #5
mechanicalman
Even though a lot of people, myself included, have re-used them and had no problems, I was hoping someone who does it for a living would respond and I am going to replace them. Like you say, cost vs safety not that much.
Thank you.
