Rear Sway bar
I have heard that a 82 to present Camaro rear sway bar will work with 67-72 trucks. I have only seen it used with coil rears. Does anyone know if it will work with leafs??
Thanks 70short/step |
I'd think the bar would hit the leafs. You might be able to raise it to miss, or if you used a flip kit to lower the truck, i think that would cure the problem.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
