![]() Join Date: Aug 2001
ammeter question
i have noticed that my ammeter needle does not really seem to move. it used to (i thought) be just right of center towards "c" when the engine is running. if you were to turn on the lights with the engine is off, it would go left of center towards "d". now it stays just right of center all the time. bad gauge? bad ground? Thoughts
![]() Join Date: May 2002
Check the small fuse holders near the headlights--they blow or corrode regularly.
Stepsides look like real trucks! Smitty ![]() |
member #16
![]() Join Date: Dec 1999
diagram
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
just did some digging using the search.......looks like the ammeter may not work properly with a one wire alternator. if so, is there a way to get the gauge to function properly using the one wire setup?
member #16
I dont know why it wouldn't work with 1 wire alt. The 18ga. b/w wire ties into the 12ga. red alt same as before. I would still check fuses and connections, it should work. Good luck John.
the gauges do go bad i have yet to see one that actually works in one of these trucks
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Depending on how the battery wire was run from the alternator as John mentioned should not affect the amp meter. If you ran the wire straight from the alternator to the battery and bypassed the large red wire going from the battery to the firewall then it could affect the meter. Most installations use the existing wire and the meter will function very well.
Jim |
thanks guys......i will check the fuses when it warms up a bit.
