09-01-2014, 07:47 PM | #51 | |
Re: Cutting up old Cab / Extra parts
The box ends up being 43x43x9. The 9 is a rough estimate of it's widest point. It weighs about 16 pounds. Let me know what you want to do. Thanks!
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
09-02-2014, 12:16 AM | #52 |
Thanks DD1....!!!! Ill get a quote tomorrow at work and let you know asap... Shoot me your zip code...
09-02-2014, 12:26 AM | #53 |
Zip code would help, huh? 10901.
09-02-2014, 03:32 AM | #54 |
Hey, sorry for being a pain, but I've had a mind change - again. I do want the left/drivers kick-panel vent if possible. Don't need the whole left side though, just a square cut around the vent opening itself.
Something like this: Assuming the vent opening itself is in good condition. That'd be the difficult part to fabricate, so it'll make life easier. |
09-02-2014, 01:41 PM | #55 |
DD1... I guess you will have to sell the sheet-metal pieces to the next person in line...
because of the dimension UPS ground would cost 107.55 to get them from you to my shop.. With those dimension they go by the size instead of the weight so its like double the cost... Sorry if it was a big inconvenience to package them up to ship... I do appreciate your efforts! |
09-02-2014, 07:56 PM | #56 | |
Jess, you are up. If you still want it, let's chat and we can arrange for you to pick up everything!
09-02-2014, 08:00 PM | #57 | |
The passenger side is lousy, so I am surprised the drivers side is in decent shape. Here is a pic from the inside, and I will get a pic of the outside for you, probably tomorrow.
09-02-2014, 09:26 PM | #58 |
Ok thanks sounds good to me ill P M you my info
thanks again Jess
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
09-03-2014, 03:55 PM | #59 | |
Suppose I should confirm now, you have no problem shipping to Australia? At my expense of course. |
09-03-2014, 04:07 PM | #60 | |
PM me the information I would need to figure out what shipping would be. I'll get you the pic of the outside a bit later when I go out to the garage. Hopefully it will be in good enough shape for you. Based on the inside I think it will be fine, but you never know.
09-03-2014, 11:54 PM | #61 |
Hey Russ, I sent you a PM. The outside does not look anywhere as nice as the inside.
09-12-2014, 08:25 PM | #62 |
Hey Doug, i got your piece all boxed up and ready to ship. What's your zip code? I'll pic a random OR zip to get an estimate and PM you. I can figure out the actual cost when I get your actual zip.
09-12-2014, 09:32 PM | #63 |
Zip is 97801.
72 Chevy Cheyenne K10 4x4 LWB, 4" lift kit, 350/350/NP205, rebuild in progress. |
09-12-2014, 09:45 PM | #64 |
09-13-2014, 09:30 AM | #65 |
Hey Doug, I sent you a PM. Repackaged it as you suggested. I think you will like the revised shipping price.
09-22-2014, 01:13 PM | #66 |
Received the back wall section today....Thank you very much!!!!
09-24-2014, 12:12 AM | #67 |
You are welcome. Thanks for your patience with me getting the piece cut off and sent to you.
09-30-2014, 12:09 PM | #68 |
I need a one foot long piece of the rear window lip. I found two little rust holes when I took my rear window out. They are on the outside of the cab, just under the rubber trim. So I would want a piece that goes from the lip, up about two inches into the roof.
If you need me to, I can post a pic of what I need
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
09-30-2014, 01:02 PM | #69 | |
10-01-2014, 10:09 PM | #70 |
OK, here are a couple of pictures. One is of the window lip, with the dimensions I think I need. The other one shows both holes. I think anywhere along the lip will be fine, except the radiused corner.
10-01-2014, 10:21 PM | #71 |
Yeah, I think I can do this. I'll send you a PM.
10-04-2014, 12:54 PM | #72 |
Hey, piece cut and being shipped out today! Sent you a PM with pics. Thanks!
10-04-2014, 03:32 PM | #73 |
Thanks, looks good. Have a good trip!
10-04-2014, 03:46 PM | #74 |
