Old 10-04-2014, 09:09 PM   #1
franken
Re: please help me, its still dieing......
"Starting again takes a lot of pumping of the gas pedal and shifting requires very high RPMs to keep the engine from dying."
That sounds a lot like a vacuum leak. Have you tried spraying carb cleaner around the base of the carb and on the intake manifold where it bolts to the engine? An increase in idle speed indicates a vacuum leak.
franken is online now   Reply With Quote
