Old 10-06-2014, 08:32 PM   #1
400/400
Re: Ol' Brown - 1985 K3500 SRW slow build
Cool truck. Looks like your truck is the same color as my '85. Is it Indian Bronze Metallic?
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 10-08-2014, 09:38 AM   #2
tip
Originally Posted by twangismythang View Post
Nice lookin truck, I'm in to follow the progress..........
Originally Posted by MTCK View Post
I used some POR15 on my floor pans after I took the little bit of rust off with an abrasive disc on a die grinder. I scuffed the por15 in the door jambs where it was exposed then primed and painted.
I'm definitely looking at POR15 for the floorboards after repair. Then hopefully some FatMat and a black carpet kit.
It sure is. My last C30 was the same color, it looks really good after some polishing. Hopefully my current truck's paint will look as good.
This was the C30 fender after some work:
tip is offline   Reply With Quote
Old 10-08-2014, 07:30 PM   #3
400/400
I used Chassis Saver, similar to POR 15, on my floors. It's intended to go on rust for good adhesion. I sanded all non rusty metal well with 60 grit sandpaper before I brushed it on. It seemed to adhear pretty well then I installed some insulating mat and a thick rubber floor liner.
Old 10-08-2014, 10:48 PM   #4
y5mgisi
Second Chance Program
y5mgisi's Avatar
For the polishing, i used nufinish on my 77 and couldnt believe how good it turned out! Here are some pics of when i was doing the hood.
Before,
After,
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-11-2014, 09:28 PM   #5
tip
Thanks for the tip, I'll have to check out Chassis Saver.
Dang, nice job!
Finally got my tires on today! I must be getting old because it took me forever and now I'm sore as hell.
Showing her good side
And her not so good side (dull):
Overall, I'm very happy with these Coopers and glad I went with Dyna Beads. There was no way I was going to mess with balancing these, especially with the little caliper clearance I have now after ditching the 16.5" wheels. She rides pretty damn good for an old 1 ton.
I was also surprised how well these tires fit with stock suspension. I'm almost thinking a 4" lift would be too much now.
Noticed today it would diesel for a second or two after shutting off, I'll have to look into that next. I REALLY don't want to put money/time into the quadrajet because I'd like to swap in a fuel injected motor (TBI at the very least) at some point.
I'm sure it needs a rebuild, but I'm afraid it will never run right after I tear into it. I bought Cliff's Q-jet "bible" a while ago but its mainly geared for high performance stuff, not an actual rebuild guide. I was "this" close to pulling the trigger on one of Cliff's SR rebuild kits for my old C30, but got cold feet and ended up selling the truck.
Old 10-12-2014, 03:20 PM   #6
y5mgisi
y5mgisi's Avatar
That sure seems taller than stockbut eieither way, it looks amazing! So the tires are smooth on the highway with the dyna beads? How much did it cost to do theset of 4 tires with tthem
