Old 10-05-2014, 08:44 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
'73-'87 Chevy/GMC upper control arm snubbers
I removed the snubbers from my upper control arms when I painted them and misplaced them. They were damaged anyway, but I've looked through countless vendor websites and have found nothing. Are these being reproduced?
They are the triangular shaped rubber snubber that installs from the bottom of the upper control arm and protects the control arm from interference when the suspension goes into full droop.
Any help would be appreciated.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-05-2014, 09:18 PM   #2
J Knight
J Knight's Avatar
Re: '73-'87 Chevy/GMC upper control arm snubbers
http://www.classicparts.com/1960-91-.../#.VDHtuHl0xdg
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 10-05-2014, 11:14 PM   #3
chevyrestoguy
Thanks for the quick reply, John.
Those are good for the '60-'72 C10/C20, and the '73-'90 C20/C30 models. Unfortunately, they wont work for a '73-up C10. I upgraded my '64 with a complete suspension from a '79 C10. The C10 style is rectangular in shape. I have even gone to the wrecking yard to get a pair, but when they put the trucks up on the stands and remove the wheels, the suspension droops and pinches the snubbers. They won't let you bring in the proper tools to bust a front suspension apart, and it wouldn't be worth the effort for a cheap piece of used rubber.
My build threads:
Old 10-05-2014, 11:21 PM   #4
bdiamond
Energy suspension makes them in poly. Would that work? http://energysuspension.com/assets/f...on-catalog.pdf
Bumpstop pictures and dimensions are on page 11
bdiamond is offline   Reply With Quote
Old 10-05-2014, 11:25 PM   #5
J Knight
J Knight's Avatar
Sorry man, I read 60-91 on the heading....didn't notice the small print at the bottom.
John
Old 10-06-2014, 10:00 AM   #6
chevyrestoguy
Thanks! I think that this may be my best option because it appears as if finding a stock snubber is probably out of the question. I've got Energy Suspension stuff all through my suspension anyway, so why settle for rubber?
My build threads:
Old 10-06-2014, 08:11 PM   #7
Axle
Axle's Avatar
LMC doesn't picture the rectangular one, but the parts list breaks out the C10 with a separate part number for the rubber bumper.
Since I can't remember what it looks like, can a lower be used and trimmed to shape?
http://www.napaonline.com/Catalog/Ca...214_0324832371
Alex.
Axle is offline   Reply With Quote
Old 10-07-2014, 01:19 PM   #8
surly66
surly66's Avatar
Try this one: http://www.amazon.com/dp/B000C59YMS/ref=sr_ph?ie=U... http://www.amazon.com/dp/B000C59YMS/ref=sr_ph?ie=U...
Good luck.
surly66 is offline   Reply With Quote
Old 10-07-2014, 01:21 PM   #9
surly66
surly66's Avatar
Amazon.com: Moog K6598 Front Upper Control Arm... Amazon.com: Moog K6598 Front Upper Control Arm...
You'll have to copy and paste...sorry, the link didn't work in my last post.
Old 10-07-2014, 01:23 PM   #10
surly66
surly66's Avatar
good lord...I can't get the link to post. sorry - new to this stuff.
go to Amazon and type in K6598 - $6.34 ea.
Old 10-07-2014, 10:21 PM   #11
Axle
Axle's Avatar
Try this link this link
