Old 10-07-2014, 02:22 PM   #1
134tessier
1972 A Arms and rear differential questions.
Hello, I have a stock 68 C10 with a 3" and 5" lowering springs. I recently picked up some parts off of craigslist. I have a couple of questions if you could help me out. First, the rear axle that is 5 lug with leaf springs was among the parts. Will the axles fit in my rear axle with coil springs. I would like to convert to five lug. Secondly, a set of upper and lower A arms with disk brakes was also among the parts. Will the spindles directly fit my arms on my truck? I really hope it is that easy and would appreciate as much help as possible. Thank you in advance.
134tessier is offline   Reply With Quote
Old 10-07-2014, 02:45 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 1972 A Arms and rear differential questions.
The rear axles will not swap over, as they are wider than your 68 axles. You will need to at least change the upper ball joint on your 68 control arms to use the 72 spindles (you may need to change the lower too, I can't remember now), and the outer tie rod ends will need to be changed.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-07-2014, 10:42 PM   #3
bsampson
Regarding the rear axle, leddzepp is right; you can't swap just the axles. If you wanted to make the parts work, you could swap out the entire rear end, assuming the gear ratio is desirable, condition, etc. It would involve cutting off the old leaf spring perches and welding on some new trailing arm axle seats ($40 from ECE or CPP).
bsampson is offline   Reply With Quote
