09-18-2014, 05:47 PM | #1 |
Fuel line, brake line routing on 72
Does anyone have pictures of fuel and brake lines inside the frame rail below the fuel tank... Or know of a thread..I have new pre bent fuel and brake lines and want to make it look good...thanks
10-05-2014, 08:10 PM | #2 |
Re: Fuel line, brake line routing on 72
I'd be interested in seeing this as well.
jeff |
10-05-2014, 09:11 PM | #3 |
I have pics. I'll try to get those up tonight.
If I forget, drop me an email or keep "ttt" this thread. |
10-05-2014, 09:16 PM | #4 |
Below the fuel tank? Doesn't the tank connect to the line via gas hose?
project: "my happy mess" |
10-05-2014, 09:44 PM | #5 | |
Here are my pics of my fuel and vent lines (second upload attempt). 1). Left to right: fuel line, rear part of vent line, front of vent line. 2). Under cab: top is rear of fuel line, middle is brake line, bottom is rear of vent line (notice is passes through the frame member). 3). Under passenger side door: the connection of the 2-piece vent line. 4). Vent line front: here the vent line passes through a spring and attaches to the frame via a clip. The black hose connects it to the charcoal canister. These are all the pics I have on file. I hope they help. |
10-05-2014, 09:48 PM | #6 |
I'm not sure if this is what you are asking for, but here are 5 pictures tracing the lines from front to the tank connection on my 69 3/4 ton. I know the front lines are different for your disc brake 72, but these are likely the same. Perhaps someone can confirm.
Edit: Oops... forgot about your vent line... Last edited by FirstOwner69; 10-05-2014 at 09:58 PM. |
10-05-2014, 11:25 PM | #7 |
Never heard of Wrecked Chevy - though I'm sure you have good intentions He asked for 'below the fuel tank' not the entire line. And look, you've got the the gas hose.
10-06-2014, 12:20 PM | #8 |
On a 72 shouldn't there be 3 lines that run in the frame?
1. a line that runs to the charcoal canister 2. a fuel line that runs to the fuel pump 3. a return line that runs to the fuel pump. so with those three plus the brake line there would be 4 hard lines running in the frame? In the ten ring - so from top down you have the fuel line, brake line, then vent line. does yours have the return line? my fuel pump has two connections on it. thanks jeff |
10-06-2014, 10:30 PM | #9 |
I got a question, 350 sbc w 4barrel, fuel line from tank to fuel pump size 3/8
307 sbc w 2barrel the same line would be 5/16 Is this correct? Just removed the tank from the cab and installed a new fuel tank under the bed so I'm running new fuel line from the new tank to the fuel pump so wanna get this correct on the fuel line size. I have a 350 sbc w a 4 barrel carb..
Things happen for a reason! |
10-08-2014, 10:27 AM | #10 |
WORTHLESS CRUISERS
Run 3/8.
Scott Hammond Lancaster, SC 1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454 If you don't live for something, then you'll die for nothing. www.xclusive-images.com |
10-08-2014, 04:13 PM | #11 |
X2 3/8" line is what you want.
