09-18-2014, 01:35 PM | #1 |
Coil U-Bolts -- will these work?
Link to U-Bolt kit
These are "Round Bend 3/4 x 3.5 x 10.5 Grade 8 U-bolt Kit" and are $35 shipped to me. I read that the stock are 3-3/8", does the extra 1/8" allow any play that I should worry about? I found other U-Bolts significantly cheaper, but they are 9/16" and 5/8" instead of 3/4". The are 3.5" diameter also and probably thinner because they are made for leaf springs. I'm assuming I can't run those... but can I?
1968 LWB C20 / AC / Wood Bed |
09-19-2014, 09:14 PM | #2 | |
Re: Coil U-Bolts -- will these work?
09-20-2014, 05:22 AM | #3 |
Why do you need them?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-20-2014, 08:53 AM | #4 |
just go to local spriring shop and get the vright ones made for you
09-20-2014, 08:54 AM | #5 |
Why not order the correct parts?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-21-2014, 12:11 PM | #6 | |
I think these are correct -- at least the 3/4" bolts. I'm looking for the extra 2" in case I want to do lowering blocks.
09-21-2014, 01:03 PM | #7 |
hmmm?? howv is it I could find 120 or so places in your home town in about 30seconds thanks to google and you cant find one???
09-21-2014, 08:21 PM | #8 |
Please, tell me how you found them/what your search terms were. I'm thinking maybe I'm not searching for the right thing. If I type in "spring shop" near Raleigh I just get a bunch of general shops like Firestone...
09-23-2014, 10:40 AM | #9 |
So, nada? Not trying to be a pest but I do need to find some good shops soon to finish my current project.
09-23-2014, 06:54 PM | #10 | |
leaf and coil springs Raleigh NC Learned helplessness is a mental state in which an organism forced to endure aversive stimuli, or stimuli that are painful or otherwise unpleasant, becomes unable or unwilling to avoid subsequent encounters with those stimuli, even if they are escapable, presumably because it has learned that it cannot control the situation. Guess all of this truck stuff is too much for him. |
09-23-2014, 08:26 PM | #11 | |
Result 2 is yellowpages, already checked there Result 3 is a tire shop in Sanford, NC Result 4 is *this thread*!!! Result 5 is a job finding website... I don't see that you've quite made your point. Find me one single place and tell me how you found it, and I'll admit that I didn't look hard enough.
09-23-2014, 10:42 PM | #12 |
Fleetpride bent mine.
3901 Jones Sausage Road Raleigh (Garner), NC 27529 Mon-Fri: 7:30am - 5:30pm Sat: 7:30am - 12:00pmToll Free: 800.662.7758 Phone: 919.779.2320 |
09-24-2014, 09:06 AM | #13 |
Thanks much, never heard of Fleetpride. Looks like there are quite a few specialty shops down there as well.
09-24-2014, 10:16 AM | #14 |
Fleetpride did mine too. they are national big truck repair (semi) company. I just stopped in on my way home from work with an old one and asked for two just like it. Mine were $36 out the door. I have heard of others getting them for less but I'm not complaining.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
10-08-2014, 10:34 AM | #15 |
I ended up ordering the bolts I originally mentioned to save myself the trip -- they look nice, grade 8 and longer nuts than stock.
10-08-2014, 04:08 PM | #16 |
FYI Classic Parts of America sells the correct ones Item#74-751 $17.95 ea.
Phone #816-741-8029 |
10-08-2014, 04:26 PM | #17 |
Good to know if you're just replacing with stock!
