10-06-2014, 01:56 PM | #1 |
Drop shocks for lowered 87?
I have 2-1/2" drop spindles on my 87 SWB. Can I run stock shocks and be ok or do I need to find a shorter shock due to less travel distance?
If so, recommend a good drop shock? Is there a shock at Advance Auto/CARQUEST, etc. made for another vehicle that will substitute? |
10-06-2014, 02:16 PM | #2 |
Sell it before it's finished
Re: Drop shocks for lowered 87?
I just did a 4/6 drop on my 81. I used Mcgaughy's lowered shocks. I ordered mine from Jegs for 39.00 each and free shipping.
10-06-2014, 02:37 PM | #3 |
If you have drop spindles only then you don't need drop shocks. If you intend on going with shorter springs later then order drop shocks.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-06-2014, 05:18 PM | #4 |
It'd be alot cooler if you did
a stock length shock is the correct shock for this application. I like how the Monroe sesna-tracks perform on a lowered truck for a more "stock" feeling ride, and QA1 adjustables if youre into handling.
10-08-2014, 10:58 PM | #5 |
I have 3" spindles and 1 coil cut off the stock springs and just put on a set of the Monroe Sensa-Trac shocks (37049) and they work great.
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
