#26 |
Old member
Well not 100% sure but the rear side markers shouldn't blink with the fronts unless some one has rewired them. I also have the LED's with diamond cut reflectors in the lens.
The camera makes it look amber when it's on but it's red! ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#27 |
Re: New Exterior Lights / LEDs
#28 |
Collector of Projects
Bringing this back up to the top... Does anyone know what board vendors sell the deluxe marker lights? I would rather support a board vendor then not, provided the cost isn't out of sorts.. So far I found the United Pacific brand with stainless deluxe trim for $27.95 each...
#29 |
Cool Truck
I have been thinking about upgrading to all LEDs, already have the tail lights just not installed yet, and I noticed you said the sidemarkers got hardwired. Are these the ones from LMC? Brothers lists LED sidemarkers that are plug and play although the picture looks like a standard lense. Has anyone gotten these ones yet?
http://www.brotherstrucks.com/prodin...=SMLD72R&qty=2
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#30 |
mine came from LMC. Even the brothers picture you linked shows wires not a plug. they aren't plug and play. there will be splicing.
#31 |
They are produced by United Pacific. The tail lights have the correct connector but the front and rear SIDE lights do not have connectors. The amber lights on the 68-72 are dual function from the factory but the red rears are not. I believe the front anmber turn lights have the connector, but I havent seen them in person. I heard they will be making some clear 69/70 front LED grill signal lights but they offer the yellow lense ones now.
http://www.uapac.com/antique/lightin...de-marker.html |
#32 | |
Old member
![]() Quote:
#33 |
Cool Truck
Thanks for the info, I wish I could find a plug in set.
#34 |
google or eBay a 1156 or 1157 male adapter .... solder and heat shrink and they're plug and play...
http://www.ebay.com/itm/1157-TAILLIG...-/390545428100 |
#35 |
Old member
Here are mine. Brakes,front turn signal's and side markers.Yes I had to swap in the flasher with ground wire to get them to work.
Bought the LED bulbs at O-Riellys. ![]() ![]()
#36 |
Old member
Front turn signals.
#37 | |
Cool Truck
#39 |
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#40 | |
Cool Truck
#41 |
Soldering upside suuuuucks, you need more practice. Do it right.
#42 |
Cool Truck
JointTech, would you mind posting a pic of the wires you tapped into up front? I was trying to wire mine into a plug by wiring the running and turn signal wires together but when I do that they don't blink unless the running lights are on and they don't use the brighter leds.
#43 |
sorry I started over. Took my cab and bed off and the frame is going to the blaster this weekend. Let me see if I can find any old pics
#44 |
sorry I wasn't as pic happy back then. I just looked in my build thread and realized I just copied what was in this thread...
#45 |
Cool Truck
Ok, thanks for the info
#46 |
I've been thinking about swapping my front signals to the clear lense plug n play led style on my 67. What needs to be done to keep them from hyperflashing? Do I need the 2 prong flashers with the ground wire? Thanks Sorry to bump an old thread, but I didn't think it was necessary to start a new one.
#47 |
A neat one I've been looking at is a "1157 led switchback " if looking on ebay , run about $35 and white when parking light and alternates between proper orange and white when flashing.
#48 |
Cool Truck
Yeah a flasher with a ground wire is all you should need
#49 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
