Drive shaft failure.
I was driving my K20 to get pizza, and my DS failed. My truck is stock height with a stock DS. With 2.5 inches of compression on the slip joint available.
So as I went through a dip about 15 mph, and about 150 feet later my truck went pop. I found a few pieces of broken cap on the street. The U joints were on the frame I got the DS from, and all I did was grease them up with the install. When I inspected the DS I found plenty of grease in there. So what should I look for as a failure point to prevent another tow home. |
Re: Drive shaft failure.
U joints fail. Maybe it was time?
GOD BLESS AMERICA! |
The answer can be that the u-joint series is too small for the application. Or possibly you are using an inexpensive parts store u-joint that does not offer strength. Maybe you are using a greaseable u-joint and it is breaking across the grease fitting hole. The corresponding yoke is damaged or distorted and causing premature failure.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
The DS was greaseable u-joint from the project frame I got, and likely what was installed in 1979. If a aftermarket u joint was used it would of been in the late 80's before it was parked from a tree hitting the cab, and parked. I do not see evidence of the u joint being anything but old though, and used. The cap that failed was broken in pieces, and I do not see damage on the + piece. I only quickly inspected as it was getting dark.
I will pull it off in a few hours when the chores are finished up. Of course it could of been the sound of 260HP 350 crate motor with bolt-ons that scared it to death. |
